Question about Homelite Garden
Homelite trimer 18.0v charger, battery, yellow
Homelite trimer 18.0v charger, battery, yellow light and green light on, won't charge, refer to manual but lost manual
Homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
Posted on Oct 22, 2010
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
I bought a Ryobl Power Drill 14.4volt last week at a D.I.Y. store and have found when charging the batteries the light on the charger is Yellow. In the instruction manual they only mention Red when...
yellow usually indicates a HOT battery and is waiting for a cool down before recharging or it can mean a defective battery/charger. If you just bought this unit I would take it back for warranty replacement.
Jul 09, 2011 | Ryobi Drills
Battery not charging. Orange and Green light on charger. 18V Plus one system
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Jun 24, 2011 | Ryobi Multi-Volt Battery Charger
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
Does anyone have a link for the battery charger for a Scooter Store Jet 3 mobility scooter that defines the different light meanings. The scooter is 6 years old but before I purchase new batteries ($112.00...
saying to refer to the manual provided with the charger for a complete indication of these indicators do you happen to have a make or a model number on the charger or the manual? if you dont have the charger manual you may want to try calling this number its the scooter store and they can send you one for your charger and also answer any questions that you have Thanks again
Rick
Call us toll-free at
1-800-391-7237
Dec 19, 2010 | Jet 3 Ultra Power Chair
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Oct 06, 2009 | Ryobi Multi-Volt Battery Charger
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
Garden Logo
812 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
