Question about Refrigerators
Fridge/freezer modelFRC150FFS6.0CF Fridge on
Fridge/freezer modelFRC150FFS6.0CF Fridge on aregular basis now loses its cool as the vent supplying cold air becomes blocked. The engineer comes out and clears it by using a bloody hair dryer. Surely a design fault? Any suggestions ideas. Item is less than a yearold.
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
Posted on Sep 12, 2009
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
My refrigerator model is FRT8S6ESB8, it's frost free. But now have a problem. It is too cold in the freezer (have ice and frost) and is not cooling in fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Frigidaire Refrigerators
Freezer compartment freezes okay to at least -5 degrees fridge will not cool below 17 degrees
Typically, the fridge gets its cool air via a vent from the freezer. If this vent becomes blocked, then the fridge won't cool. If there is nothing obvious blocking the vent (like a plastic bag) on either side then it is possible the vent is clogged with ice. To fix this, move your food to a cooler and unplug the fridge long enough for the ice to melt (12-24 hours).
Mar 03, 2011 | Refrigerators
Freezer is working, crispers are cool, fridge is not...55 degrees even at the highest cool temp.
Typically the fridge gets its cool air from the freezer via a vent. There is likely something blocking that vent like ice. Move your food to a cooler and turn off the fridge long enough for the ice to thaw (12-24 hours).
If this does not resolve the problem then dismantling of the vents for cleaning will be required.
Mar 03, 2011 | Kenmore 65232
Please help mdl # BX21VL s/n 9910131900 freezer works fine refidgerator does not. no cold air blowing out of vent
If you have an error code showing or flashing then try is Powering off the FF at the AC mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
Try completely defrosting the FF as despite common belief these units are not totally frost free.
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In modern uprights if the freezer part is working OK and the fridge is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
In stand alone fridges the answer could also be that the cooling panel at the rear is dirty and needs thoroughly dusting / cleaning / unblocking and checking that there is enough space around it to cool properly and that it is not near any heat sources such as an oven, air vent, microwave exhaust, etc.. It could also be caused by a problem that has resulted in a loss of the refrigerant gas and will need regassing by a service engineer. Also check that the thermostat is working correctly, turn it up and the fridge compressor motor should kick in, turn it down and the motor should turn off. Also make sure that the fridge is not iced up, or overloaded, so cool air cannot circulate inside it. Best call a service engineer asap.
Nov 11, 2009 | Amana ABB1927DE Bottom Freezer...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Warm fridge
If you are sure the fan is running either the damper motor (vent in fridge section) is bad and not opening or there is ice in the return vents and not letting air circulate. Take out the bottom drawers in the fridge and look down the two return vents in each corner with a flashlight. If they are iced up the top will not cool.
Nov 17, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
