Question about HP DeskJet F380 All-In-One Printer
F340 paper jam
Again, had a jam, removed paper, now nothing will print... shows a paper jam error... tried unplugging, no luck... any ideas?
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
My hp deskjet f4140 keeps showing a paper jam and won't print the page I need, there isn't a paper jam.
There is probably a problem with the position of the cartridge carriage. Try reinstalling the cartridge and make sure that the carriage is in the center of the cartridge access area and the center of the cartridge assembly bar. If it is not try moving the cartridge assembly in either direction and restore the printer for printing. Note any sounds as the cartridge attempts to go to its home position. Any grinding noise may indicate that the position of the cartridge needs to be adjusted. Be patient and adjust the cartridge position again until no grinding sounds are heard. It may help to unplug the printer for 30 seconds between adjustments. Good Luck!
Nov 05, 2009 | HP Deskjet F340 All-In-One Printer
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Jun 29, 2009 | HP DeskJet F380 All-In-One Printer
I cleared paper jam, printer won't respond, still have error messages
turn it completely off..let it sit for the length of a cup of coffee..try it again..
Oct 13, 2008 | Lexmark E450dn Laser Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Deskjet f340
You have a paper jam. get a torch and thoroughly check doen behind unit where paper goes after removing all paper. Oopen cover, let carriage move, once settled, check everywhere her too, all around, rollers, near carriage, teeth, sides, etc, and remember it can be the tiniest slip easily missed. Good luck.
Mar 06, 2007 | HP Deskjet F340 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
Seeker5211
Seeker5211
