Question about Garden
I need to replace the fuel line on my John Deere LT 160 riding mower. I do not know how to access the end of the line that attaches to the gas tank. Please help.
  • 389 Answers
Remove the seat and the fender/platform from the operator station this should expose everything you need to get at
Posted on Sep 14, 2009
How do i drain wrong gas from my tank.
There is a gas line hose which is attached on one end to the bottom of the gas tank, and which then will run to a gas flow shut-off valve (if your mower has one) or to the gas filter or fuel pump. Take the hose loose at the nearest point to the tank, remove the gas cap, and simply drain the gas into a suitable pan or other receptacle large enough to hold the volume of gas that's in there. Try to make sure the mower is level front to back and side to side when you do this. Hook everything back up and you should be good to go.
Aug 02, 2016 | John Deere Riding Lawn Mower. D140 48 in....
Can I install a GAS SHUT-OFF VALVE on my John Deere D130?
just drain the tank, find the fuel line and put a valve in the fuel line like on snow blowers and lawn mowers.
Jan 18, 2015 | John Deere Garden
Our John Deere 110 is killing our grass in short stripes that look like equal signs
sounds like a fuel leak from the tank to the caburetor. Your mower has a fuel pump that pumps the fuel from the tank to the carburetor and when you are running the mower the fuel is leaking out the fuel line onto the grass. Check the fuel lines for cracks or splitting and replace it with fuel line from a lawn mower shop.
Jul 06, 2012 | John Deere Garden
John deere 116 no fuel to carb
Blocke inline filter, or if it has a pump, then this is not working.
Feb 29, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
I have a kawasaki engine fb460v-cs00 in my John Deere Riding Mower and I am trying to find a diagram for the gas tank, lines and connectors. Where can i find that info?
You can get this information at any John Deere dealership or at your public library. I don't really understand your problem. All fuel tanks have a port on their bottom side where a fuel line is attached that runs directly to your carburator, with possibly a filter in between.I hope this will make things a little easier for you. GOOD LUCK.
Jun 17, 2011 | kawasaki Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
How to repair a gas line on a sst18 john deere lawn mower
make sure the tank is empty and then remove the clamps holding the line on the tank and the carb take the whole thing with you to service center and ask for a direct replacement for your fuel line (may also include a fuel filter)...good luck
Apr 07, 2010 | John Deere Air Cleaner Bowl For Tractors
Need to siphon gas from gas tank of a John Deere
Go to the store and buy a siphon you would use for a kerosene heater.
You can get the fuel out with this item. When you fill it back up add some "Seafoam" fuel additive. It will help keeps it running better.
Good Day.
Oct 12, 2009 | John Deere Garden
Garden Logo
606 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
