Question about Cyberhome DVR 1600 DVD Recorder
Whiny dvr I have a generic dvr with no visible name brand. About two days ago it went dead. The monitor went blank (except for a couple of gray wavy lines on a black screen), all of the buttons became non-responsive, and it started emitting a high pitched whine. Is it just completely fried out, or is there something I can try to fix it.Thanks for the help.
  • iraindogi Sep 12, 2009
    I had a suspicion it was the drive. Thanks for the assurance.
    Unfortunately, now I have a new problem: I can't find it. I opened the unit and didn't find anything matching the description, just circuitboards. It might be under one of them, but it would have to be unbelievably small.
    I also thought it could be with the removable storage disk (this is a security system DVR, not one for television), but when I removed it the unit still made that high whining noise. If the whine's coming from the faulty drive and I took out the removable disk and the whine remains, then the drive is elsewhere; or the whine's not coming from the drive. So, it's not there or not a drive problem.
    To confuse matters a little more the removable unit looks a hell of alot like a hard drive and some of the info printed on it seems to back this up (e.g. "drive perameters: LBA 488397168 250.0 gb").
    Furthermore, I know it works, because I switched it with another unit with no problems. So, from this view it looks not to be a drive problem.
    So, to recap: it looks and sounds like a drive problem. However, if the drive is located in the removable unit, then it can't be. Finally, if the drive is located elsewhere, I can't for the life of me find it.
    Sorry if the post is a little confusing (i just reread it, not my best). I'm going on almost no sleep.
    Any more help would be greatly appreciated.
    Scholar:
  • 77 Answers
Sounds like the hard drive in the dvr is bad - they're easy to replace though - just follow the steps below.
  1. Step 1 Disconnect your DVR by unplugging any cables connected to it, including the power cable. Remove the screws located on the back of the unit that hold the top cover in place. There are usually two to six of these screws, depending on the model of DVR. Lay these screws in a safe place where they won't get lost, and slide the cover off.
  2. Step 2 Locate the hard drive. This is a rectangular metal unit that measures 3 1/2 inches wide. It is usually located away from the other hardware, often in its own bracket. There will be two to four screws holding it in place. Remove these, disconnect the cables connected to the drive, and slide it out of the system.
  3. Step 3 Check the label of the drive to see if it is IDE or SATA. It will say which one of the two interfaces it uses. Any replacement desktop hard drive of the same interface type will work in your DVR. Avoid using a laptop drive, because they won't fit and aren't designed for the high-stress environment of video streaming.
  4. Step 4 Place the new drive into the brackets, and replace the screws that were removed from the old one. Plug the data and power cables into this drive. They will insert the same way they came out of the old one. Once the drive has been installed, put the cover back on the DVR unit, and replace the screws. Hook the DVR back up to the television, and it will be ready to record.
Posted on Sep 12, 2009
I have a sunluxy H.264 network dvr i cant get any
You must connect a mouse to the dvr and right click. If you can return it I would, that is a made in China generic dvr that anybody can buy and have their name put on it. Spend a couple hundred bucks more and get a name brand dvr that has a real tech support. I run into similar dvrs all the time under different names and it's the same dvr. The better dvrs are made in Korea, May sound funny but true. All these dvrs that are so low priced are typically junk and will give nothing but headaches. They may last a year or two before the video card, motherboard or hard drive fail. I can buy those dvrs on alibaba.com by the pallet for under $50 with my name on it. We don't do that because we like to keep our customers. Good luck with that.
Sep 03, 2014 | Home Security
Monitor went blank
my system is recording but i cn not see my truck on camera
Aug 06, 2012 | Revo 16 Channel Video Security System Dvr...
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
Screen blanks out seconds after being turned on. A small whiny sound can be heard for the short time its on.
believe me u cannot fix this problem you can only make ti go away, when monitor goes blank, hit windows button on keyboard and programs will open, on the TASK BAR you will see blank page windows, double click it away, usually last all day, regard robert
Aug 23, 2009 | Acer Computers & Internet
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
Scrren went gray
the screen is dead, take it to your local cell phone service provider
Aug 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG old but brand new blank screen green light making a tik,tik,tik sound.
Nothing you can really do yourself with that. I would call manufacture and get solutions from them. When it comes to monitors, unless your skilled in repairing them you will only do more damage to them. If you really feel like jumping into it and have nothing to lose you should be able to find a service manual on this monitor here http://www.eserviceinfo.com/most_popular/list_8400.html and rip it apart to find the piece to replace.
Jul 17, 2007 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Cyberhome DVR 1600 DVD Recorder Logo
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
