Suddenly the laptop stops working and when you try to turn the computer on the computer does not star, it seems a motherboard failure, do you know what the main problem could it be
  • 600 Answers
Does the fan work? could be overheating- could be the HD is starting to fail-run scandisk-could be ram problem
Posted on Sep 12, 2009
Testimonial: "Was helpfull!"
  • 79 Answers
Try reseating the RAM and any pci card plugged in underneath. If those don't help - it's probably a crack in the board or a soldered joint broken. Very hard to fix in many cases.
Touchpad failure
Is it turned on? Try here for a User Manual: http://us.acer.com/ac/en/US/content/drivers If it still doesn't work , return the computer.
Mar 20, 2013 | Acer Aspire V5-171-6860 - Core
I have a nec computer which is often damaged . last month there was a sudden sound and the computer stopped working , i have cleaned the ram but nothing happened .later the computer showed lines on the...
1) Removed graphics card? Sounds like this is an NEC desktop computer, not laptop. 2) Loud pop? Have a look at this Vai,
http://capacitorlab.com/visible-failures/index.htm
See if one exploded.
(Those are Radial Aluminum Electrolytic Capacitors. They do pop. What REALLY makes a loud bang, is if a Solid Polymer Capacitor pops! Explode like a small grenade inside your computer case!
May not even see it anymore. Just a place on the motherboard where it was, and shrapnel from it all over inside the computer case.
When THEY pop, you KNOW it! )
Regards,
joecoolvette
Nov 26, 2012 | Computers & Internet
My toshiba satellite U505 turns off suddenly when i turn it on. What might be the problem
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-toshiba-satellite-u505-ac-adapter-19v-3-42a.html
Nov 22, 2012 | Toshiba Satellite U505-S2940 Notebook
My Del studio 1737 laptop is suddenly stops working and it is not working at all . power adapter light will turn off when i connecting to laptop. Please help me
if the AC adapter LED goes out when connected to the power connection of the system, then the failure is most likely the motherboard has failed.
Try a different AC adapter, if no change then motherboard
Jan 22, 2011 | Dell Studio 1737 Laptop
A few months ago my acer aspire 5100, all 3 usb ports stopped working. Now my computer does not even start. I have tried switching it on... somtimes the speaker makes scratchy noises otherwise no such...
It does sound like a complete motherboard failure, do you have a recovery disc for the laptop? remove the hard drive and leave it out, remove one stick of ram, remove the main battery, and remove the wireless card. Now fire up the computer to see if the acer logo comes up and then it should go to blank screen with the cursor blinking, if it works to this point, turn off computer. Now install the hard drive and load the recovery disc, make sure the boot sequence is set to start the dvd driver first, if everything works and you have full control we are starting to get somewhere, if it fails, this is where I would change the hard drive and see if that makes the difference, if it does, replace the ram and wireless card back into position, and last the main battery. If all this fails it leaves the motherboard as the problem. one thing I forgot to mention swap out the ram if windows freezes.
Jan 08, 2011 | Acer Aspire 5101WLMi Notebook
D610 Dell Laptop
it seems to be a problem with motherboard as you said you have replaced power supply and ac adaptor , try disconnecting external pheripherals do a flea power it doesnot start then you will have to replace motherboard
Jan 09, 2010 | Dell (F2273) Motherboard
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
My Wireless LAN button has stopped to work
I just reloaded windows XP after cpmplete failure , Lan just seems to be Missing Can not find in device Manager
Dec 24, 2008 | Acer Aspire 5610-4648 Notebook
Toshiba Tecra M2 Series
Was the laptop on when it turned off? It may be a PSU problem but we can determine this by removing the battery. Make sure you disconnect the AC adapter while your removing the battery. Inspect the contacts and make sure`there are no black marks or any other dirt. Leave the battery out and plug in your AC adapter. Try the power again.
There are a couple of possibilities in terms of problems that I can suspect so far. Did anything out of the ordinary happen when the computer just stopped working all of the sudden.
1. Battery has failed and short circuited the contacts 2. Power supply failure 3. Motherboard could have failed in style. 4. Power contacts for the AC adapter are damaged.
Jun 15, 2008 | Toshiba Tecra M2-S730 Notebook
No sound
What is model of the motherboard of your computer or the model of the laptop that you used.
Apr 29, 2008 | Microsoft Office Standard for PC
Computers & Internet Logo
David Payne
David Payne
