Question about AEG 24 in. Favorit 60870M Free-standing Dishwasher
Aeg dishwasher no salt pellets available in Australia
AEG free standing dishwasher, öko-Favorit 6150.
No salt pellets avialable in Australia
SOURCE: My AEG favorit sensorlogic turbo
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over, or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 3006 Answers
SOURCE: AEG Favorit fails to release detergent most of the
There is either food debris blocking the action of the dispenser lid, or the solenoid which releases the door is sometimes failing to operate. The latter fault can be due to either a faulty solenoid or a loose/damaged cable connection anywhere between the main board and the solenoid: bear in mind that every time the door opens and closes there's a flexible connector which gradually fatigues and there are electrical connections which can be loosened if the door is regularly allowed to slam shut.
It's not really a DIY fix unless you are a competent and experienced home appliance repairer, but you can check for any food debris around the dispenser lid. If in any doubt run the machine empty using dishwasher cleaner. The possible electrical faults I've mentioned aren't necessarily expensive in terms of parts, but the labour will typically be about one hour.
An alternative is to use the new detergent dispenser from Finish. This sits in your machine, preloaded with twelve doses of detergent which are automatically released with every wash. It's an expensive way to buy dishwasher detergent, but it's a quick and relatively cheap fix which may buy you time until you can afford a proper repair.
If you do think that you may be able to diagnose and repair the fault on a DIY basis then I highly recommend the Haynes Dishwasher Repair Manual which you can either buy or perhaps borrow from a public library.
I'm hope that you have found my reply to be of use, all that I ask in return is that you take a moment to rate my answer.
Posted on Feb 28, 2010
Testimonial: "I haven't tried the various suggestions yet, but am in awe of Obertelli's completeness and ability to troubleshoot with very little information. Tops!"
SOURCE: in which way can i reset my dw AEG favorit F 86050
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Posted on Oct 12, 2010
0 characters
1 Points
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
I need a wiring diagram
Can't pull one up online under the manufacturer Favorit?
Apr 22, 2014 | AEG 24 in. Favorit 40650 Free-Standing...
Aeg favorit 88080 service code i30
In my case, it turned out that the faucet was completely clogged with scale deposits. Replacing the faucet solved the problem, so by all means, check this before you take any other action!
Jul 10, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Wont heat or dry dishes
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
Where do you purchase the dishwasher salt from I recently purchased the AEG favourit and am having problems sourcing the salt....(brisbane area in Queensland Australia)
if you are in a soft water area then salt is not needed but is essential in a hard water area. normally available from any supermarket
Jul 10, 2008 | AEG Dishwashers
AEG Favorit 420 Freestanding dishwasher
i have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Dec 26, 2007 | AEG 24 in. Favorit 40310 Free-standing...
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Oct 26, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG 24 in. Favorit 60870M Free-standing Dishwasher Logo
251 people viewed this question
Top AEG Dishwashers Experts
Michael Thomas
Michael Thomas
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
