Question about Samsung Televison & Video
My Samsung 650 series 61'' DLP tv turns on and off repeatedly. I heard a buzzing noise and shut the tv off for a while. I plugged it back in and it still turns on and off but I didn't hear the buzzing noise. What would cause that and how do I fix it?
  • 1 more comment
  • jimbofury Sep 12, 2009
    ok I cleaned the areas you said too and it still turns on and off. Earlier I heard that buzzin sound and smelled something. When I put my nose close to it I can faintly smell the same thing. Did something blow?
    I cleaned the cooling fans and the areas under them but it still turns on and off. Earlier I heard a buzzing noise and could smell something. When I put my nose close I can faintly smell the same thing. Did I blow something? How can I fix it?
    i'm not sure power supply would make it do this....
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The most probable cause is the 'Colour Wheel' due to which TV is producing a buzzing noise and shutting it off for a while. You need to replace the Colour Wheel. If you want to do it yourself then you can follow the procedure from this link---
Colour Wheel Replacement Procedure
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 12, 2009
  • 11,896 Answers
This would either be a faulty relay or power supply. Power supply failure is quite common especially in newer tv sets
  • Nate Stansfield
    Nate Stansfield Sep 12, 2009
    You can test the relays with an ohmmeter in the ohm setting. You can test any capacitors with a capacitor tester and get the values from the service manual. If it is turning on, that is a good sign. It may be capacitor that is faulty.
    President:
  • 1,462 Answers
The Tv getting shutting down is a generic problem for all Samsung DLP Tv , the solution is
1. Unplug the t.v
2. Put on some plastic, rubber or latex gloves so you dont shock anything
3. Remove the lamp cover
4. Remove the big cover that covers the back of the t.v.
5. You will see a small fan and behind that is a heat sink.
6. Remove fan but don't unplug it.
7. Clean all the dust off the fan and heat sink and any boards you see covered in dust. Use a dust off can or use a cloth but be carefull.
Note: The tv has a heat sensor in it and when it detects that the tv is above operating temp it will turn off.. Dust stops it from cooling down and keeps in the heat which overheats it.
8. Screw the fan back on to the heat sink
9. Replace all panels taken off. If you don't the tv will not turn on
10. Plug you tv in and turn it on...
11. Every thing should work normal now
Note: If you had color or picture problems these steps won't help that. Best to call Samsung for those type of repairs.
RATE THIS SOLUTION
RNJ VINOD KUMAR
  • Vinod Kumar
    Vinod Kumar Sep 12, 2009
    Try lowering the backlight to less than 10.
    This seems to be a known issue with this model.
    It could be the cooling fan, and usually the noise is higher when the picture is dark or has a high contrast.
    If your TV is still under warranty, then the best thing to do would be to get it replaced. If not, you may need to call in a qualified technician to look into this.
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
Apr 04, 2011 | Samsung HLP6163W 61" Rear Projection...
No picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
May 18, 2009 | Samsung 61" Slim-Depth DLP HDTV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Buzzing noise
You need a new color wheel.  Partstore.com is a good place to get them.
Check out:  http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jun 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Buzzing Noise
Set has a defective color wheel. This needs to be replaced and your tv will go back to normal.
josh
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
