Question about Microsoft Xbox 360 Console
My xbox says its overheating when i kno its not. everytime i turn it on, the fan gets really loud then bilnks 2 red rings on the left. i have tried everythinh i could think of and still have no conclusion. if you could help me it would be greatly appreciated. thnx.
  • 767 Answers
Yes this happen some time when they get bump hard or
take a little fall . The heat sink on the C.P.U has broken the
seal with the chip and is not flush against the chip .If you
open it up turn it on till it over heats then unplug it and push
down firmley for about 5 sec on the large heat sink next to
the cd rom this should re-seat the heat sink to the chip.
Rob
Posted on Sep 13, 2009
The most common problem that causes this is that the thermal bond between the heatsink and the cpu is gone.
to fix it you can disassemble the unit and remove both the cpu & gpu heatsinks and then remove old themal grease from the heatsinks and the 2 chips. then re-apply new artic silver 5 themal
past and then re-assemble the unit.
this will usually fix any 2 red light problems with your xbox.
if not then you will need to have it professionally reworked
to fix it.
  • 6,784 Answers
Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Posted on Sep 12, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have the red ring of death
okay dont panic YET!
Try this try overheating ur xbox360 by stopping the fans ge 2 sticks small enogh to stop both fans i used two darts most people use q-tips well any way wen uv stopped ur fan s the red light s on ur xbox will still have 3 lights wait untill the lights have only 2 lit on the left hand side of the ring this is wen ur xbox will have overheated let it cook for 1min if that the unplug leave for 15-25mins to cool to room tempand boot it back up GREEN LIGHTS
Nov 27, 2010 | Microsoft Xbox 360 Console
Fixed the red ring of death, but now turn system on, the fan fires up slow to fast and then immediately quits and have 2 red lights on left side. What causes this?
2 red lights on the left side are overheating. I cant stress enough how much you dont want this to happen but if you want to order a new fan they have better fans. http://www.amazon.com/Talismoon-Whisper-Fan-Xbox-360-Blue/dp/B000H1V56U
if you need further assistance please let me know and i will be glad to help
Jun 01, 2010 | Microsoft Xbox 360 Console
I got an xbox 360 its got 2 red rings plzzzzz help!!!
Hi I went to YouTube.com and type in "how to fix red light on xbox360". It works.
Feb 02, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
2 reds
its called the e74 error or the rrod the red ring of death go to xbox home page online and find out how to send it in to get fixed
Aug 28, 2009 | Microsoft Xbox 360 Console
3 red ring and power supply
First try removing any accessories (for eg HD drive, hard drive or network adaptor) from the console and turn on 360. Plug each device back in one by one and turn on to check which device possibly causing the problem.
You should also try using another 360 AV cable sometimes this is the culprit.
If the above methods made no difference then the Xbox 360 might be overheating and which will eventually lead to RROD (Red Ring Of Death - 3 red ligthts) or E74 error message (1 red light) indicating repair.
Check whether your Xbox 360 console is still in warranty as its most likely Microsofts fault not yours and they should repair it for free
You can buy the repair kit off ebay from £4 - £7 and carry out the repairs yourself with plenty of Youtube videos on the net just google it or if dont dont feel confident i can repair for you.
If this helps please vote...thankyou!
Aug 13, 2009 | Microsoft Xbox 360 Console
My xbox is broke PLEASE HELP!!!!!!
Its called the Red Ring of Death, you need to send your xbox into microsoft to have it repaired.
Jan 10, 2009 | Microsoft Xbox 360 Console
TWO RED LIGHTS ON XBOX 360.
that means it overheating........
Oct 15, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,235 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
