Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
GE DOOR ONLY COMES UP ABOUT 3 INCHES AND STOPS. wHAT CAN i DO?
    President:
  • 3,197 Answers
Check your door springs. Most possibly a broken one. You should also remove the cover and check for a stripped drive gear. Both are common problems.
Posted on Sep 12, 2009
  • 15,935 Answers
Look for a knob on the motor housing that says WORK or FORCE, and dial it to the + side a tad and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Door Doesn't close on GE Profile PDS20SCRALSS
Check for long items, too big to fit in the fridge.
May 04, 2017 | GE Profile PDS20SBSRSS 30" 19.5 Cu. Ft....
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GARAGE DOOR OPENS ABOUT 3 INCHES AND STOPS
Check the door springs. May have a broken one. Also remove the cover and look at the drive gear. It is white nylon and is just in front of the motor. It could be stripped.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Door only opens about 3 inches
You have a broken spring on the door. Stop tyring to open door with opener immediately or you will have a broken opener and a broken spring
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
The water dispenser in my frig stopped working but it still makes lots of ice. I replaced the filter on 29 Dec 2007. I normally get 6 months out of a filter.
We had same problem! The water line gets frozen in the door, and there is no way to get to it. But, I took some 14 gauge electrical wire and would get one end hot by putting it under hot water, then put that end up the water line in the door. This might take several attempts, but it will work. A little piece of ice about 2 inches long will come out.
Mar 05, 2008 | GE CleanSteel GSL25JFTBS
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
