Question about HP Compaq Presario V2000 Notebook
Replace fan in Presario 900US
Ordinarily, I can remove all the screws underneath the laptop then gently pry off the top strip close to the screen then remove the keyboard and any additional screws underneath then gently pry the top cover off. This is often quite easy if I know the pressure points. On the Compaq Presario 900US, I can not seem to locate those points.
My goal is to access the rear fan which is not spinning. I suspect a blockage somewhere or the fan has failed.
Any assistance would be greatly appreciated.
    President:
  • 2,600 Answers
Here is the service manual for your laptop. you will need the utility Winrar to open the file after you download the file. when you open the link scroll down to the bottom where the download button is.
http://www.eserviceinfo.com/downloadsm/9046/COMPAQ_Compaq%20Presario%20900%20Series.html
Posted on Sep 12, 2009
Testimonial: "Excellent. Full step-by-step procedures for this precise model. I do not have WinRAR, but 7-ZIP works fine as well."
Instructions to remove keyboard from compaq laptop
Remove the Power Cord, Remove the Battery. Close the LCD Lid then turn the laptop over. Look inside the battery case to see if there are any screws in there, if so remove them. Sometimes the keyboard might have screws inside the battery case too. If that's the case normally you will see the keyboard icon next to the screw. The purpose of removing screws in the battery case is there might be some that hold the strip that is above the keyboard in place.
You can look at the rest of the screws on the bottom of the laptop to see if you see any that might have the keyboard icon next to it. if so remove that screw. Also sometimes there might be a screw that holds the keyboard inside the memory slot or any of the other slots so just look for them. If you'd like you could just remove all the screws from the bottom of the laptop.
Turn the laptop back over after the screws are removed, then take a small flat head screwdriver and pry the strip that is above the keyboard aloose. Normally this strip has the power button on it. Be careful removing this strip because there will probably be a cable attached underneath it.
Once the strip is removed there might be screws that hold the keyboard in place a the top of the keyboard, if so remove them. Now you can just lift the keyboard out but be careful because there is a keyboard cable underneath the keyboard that has to be removed. If the keyboard does not just come out then more than likely there are little catches that help hold it in place either at the top or on the sides, just work with one side to pry it from the catches then you will be able to get the keyboard out.
Apr 23, 2012 | Computers & Internet
X1000 power button
The power button on these laptops is easily depressed underneath the power button strip especially when the switch becomes dirty, the screen doesn't light up, and the user gets frustrated. When I find a depressed button, I take the keyboard off by removing the 2 13mm screws with the keyboard emblem from the bottom and moving the 4 tiny plates between the esc-F1, F4-F5, F8-F9, & F12-delete keys. The power strip is then removed by gently prying up near the CPU and pulling it up and toward the front of the laptop. You can then either repair or replace the button or strip. I small drop of contact cleaner down into the switch will help it function reliably. Even a small drop of rubbing alcohol will sometimes work but contact cleaner is the best.
Mar 02, 2012 | Compaq Presario X1000 Notebook
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
Replace hdd in presario 900us
Here is the way to remove the hdd from the laptop for replacement. Please go to this link. Thanks.
Jun 18, 2010 | Computers & Internet
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
CPU cooling fan failure on Fujitsu Siemens Lifebook 7010D
I have opened dozens of these in the past and i have one in front of me at the moment...the easiest way to do it is. Get a blank white sheet of paper. Close your laptop and turn it face down. Remove all the screws underneath.As you remove the screws put them on the white piece of paper.So if you remove the screw from the top right then put the removed screw on the top right of the blank white page.
When you have all the screw removed the first thing to come off is the section at the on/off button (about 1nch thick covers the six buttons and has the display on it) Open the screen flat and fully extended.Remember at the back you will need to clip off on both side the grey plastic piece.(beside 2 usb connections and network port) when this section comes off you will see 2 screws underneath for the keyboard to come off...I think you will get it from here....
PS: watch out for the wireless button on the front left... this can pop off when putting it all back together....I'd say somewhere like maplin is a good place to look for one of these fans when you have it removed....best of luck
Mar 26, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Sep 23, 2008 | HP Compaq Presario V5000Z Notebook
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
HP Compaq Presario V2000 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
