Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
My kitchenaid stand mixer fell 10 feet now nothing happens when plugged in . is it the motor?
  • 143 Answers
No, it will be the speed adjuster. Electrical danger however. Recommend authorised repairer
Posted on Sep 21, 2009
Kitchenaid stand mixer motor head fell off
You didn't say which model KitchenAid mixer you have. Assuming that it is a tilt-head, and that the metal portion of the motor housing joining it to the base did not break, the Service Manual can be had at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 16, 2017 | KitchenAid Food Mixers
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
The attachment/accessory "screw" fell into my mixer while the beaters were mixing a cake batter. The mixer froze up when it hit the "Screw" and now the unit won't turn on. Did I burn up the motor? Does...
Sounds like a classic case of the gears jumping out of sync. This is an issue that needs to be handled by a repair place or sent back to KitchenAide. The motor on a KitchenAide is very strong and it sounds like when the cap for the accessory fell in it must have somehow gotten jammed, although I really don't see how that would be possible unless there was something else in the mix as well.
Dec 04, 2009 | KitchenAid K45SS Classic Stand Mixer
My KitchenAid RRK150 325 Watts Stand Mixer started to smell more and more when used for more than 5 minutes. Now it doesn't work anymore, nothing happens when power is on. I'm not sure whether it's the...
It sounds like your problem will be in the back of the mixer then. Take the back cover off and have a look inside. Usually an electrical smell is also accompanied by sparks when the mixer is turning and often blackening of the area where the sparks are occurring. As the turning motor makes physical contact with the control plate I would investigate the area at the back of the motor. It may be that a new control plate is required.
Oct 20, 2009 | KitchenAid RRK150 Stand Mixer
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Attachments won't turn
most likely a stripped worm gear if the motor still runs but the attachments/planetary gear won't turn.
Did this happen when mixing a big batch of dough or when something fell in the bowl that shouldn't have?
Dec 16, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
109 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
