Question about Whirlpool Kitchen Ranges
The oven door has become partially unhinged and I can't get it back into place.
  • elmjan Sep 12, 2009
    I was able to remove the door and hopefully will be able to get it back on.
    President:
  • 1,462 Answers
Hi, Tough but you need to open the door all the way stick a small screw in the hole on the side of the hinge that is still on then partially close the door this will alow for you to remove the door and then you can push open with your hand the other hinge and stick a screw in the hole on the side this will keep the hinge from closing on you then reinstall the door RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 12, 2009
I have unhinged the oven door. I cannot get it back on.
how did you unhinge it .usually they need to be semi open to put the door back on .
Jan 17, 2016 | De Dietrich Ovens
THE PANEL SAYS OVEN LOCKED BUT DOOR IS OPENED HOW DO i GET IT OFF
Hi Tina:
You haven't said what make it is so here's a general approach to take.
Sometimes that door may have become partially disconnected from the hinge which could be why it's not closing.
Some oven doors remove quite easily by pulling or lifting the door away from the hinge point. If you open the door and look down where the hinges are, you should be able to see if there is any mechanical connection.
Hope this helps
Apr 03, 2015 | Ovens
Door came unhinged how do you get it back on
Since you didn't mention the model number, I have to be kind of general.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 02, 2011 | KitchenAid KHMS2050SSS Microwave Oven
How do I re-insert the Thermador oven door so it is properly in place and functional? Issue cropped up when someone cleaning it put too much force on the door and it became unhinged on one side. I was...
Sorry to read about your problem, I hope this helps you out.
this takes alot of practice, really hard to explain..i suggest you call a service company....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
I lifted the oven door off to clean it and now I can get it to go back on. Is there a trick to putting the removable door back on?
Hello.The hinge levers need to be pulled open to the first click.(partially open if the door was on)The door should slide back on the hinge arms and maybe click into place.
builderdale
Feb 28, 2010 | Kitchen Ranges
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven door won't close completely
Open the door to the partial open position and then lift up the door. It should come off. Now slide the oven out to access the screws on the side at the bottom.
Aug 15, 2009 | Ovens
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door
tough but you need to open the door all the way stick a small screw in the hole on the side of the hinge that is still on then partially close the door this will alow for you to remove the door and then you can push open with your hand the other hinge and stick a screw in the hole on the side this will keep the hinge from closing on you then reinstall the door
May 31, 2008 | Refrigerators
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
