Question about Whirlpool GMC275PD Electric Double Oven
How do I remove the oven door for Whirlpool GMC275PD?
  • 999 Answers
If there are no screws on the inside of the door holding the hinges in place, Tilt the door out to the first stop, grasp both sides and lift straight up.
Eric
Posted on Sep 17, 2009
Does anyone have the service manual
It will not let me upload here please contact me
Dec 24, 2015 | Whirlpool GMC275PD Electric Double Oven
I have a gmc275pd, and need to remove door to replace the inner glass. can't figure out how to remove the door, there doesnt seem to be a locking latch that others describe on the internet.
Open the door look at the hinge where it goes into the receiver you should see a small hole place a small short screw in the hole each side now close the door slowly hold the door while closing you should feel the hinges release out of the receivers, to take the door apart you are going to have to remove these screws to do this take the box end of a wrench pull the hinge back to take pressure off screw remove screw
Feb 11, 2015 | Whirlpool GMC275PD Electric Double Oven
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
Door stuck after cleaning cycle? Can hear latch release but door will not open. Power still good. Oven still works, just can't open door,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 16, 2010 | Whirlpool GMC275PD Electric Double Oven
Oven door will not latch
STEP 1:Grasp the handle on the Whirlpool oven door and open it to the first position.This will be a 4-inch opening
STEP 2: Place your hands on either side of the oven door
STEP 3: Pick up the door from the first position gently.Keep lifting the oven door until the door is clear of the hinge.
Thanks
Jun 02, 2010 | Whirlpool GMC275PD Electric Double Oven
Hi their i am replacing my old fan oven element. but when i pulled out the old element the wires fell down the back!!! any ideas on how to retreive them? thx
use a coat hanger as a hook to grab then but unplug the stove before you do it. You should be able to sang them without to much difficulty.
Apr 18, 2010 | Whirlpool GMC275PD Electric Double Oven
It stopped running, shows door for message. no light when the door is open.
there is a fuse that causes this. check it. if door error apears for the micro
Feb 07, 2010 | Whirlpool GMC275PD Electric Double Oven
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 | Ovens
Hooked up a new control panel and now the oven only works when the door is open! what did i mess up? microwave works. light is on when door is closed, light turns off when door is open and then oven will...
door switch connections are reversed. will need a model number and make to give better info.
Please take the time to give this solution a fix ya rating and repost with needed info.
clarkco
Mar 19, 2009 | Whirlpool GMC275PD Electric Double Oven
Whirlpool GMC275PD Electric Double Oven Logo
207 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
