Question about Toshiba 55H70 55" Rear Projection Television
Toshiba first the tv would keep going into protect mode ...now it wont even turn on
    President:
  • 4,402 Answers
Do you get a flashing led if so how many times?
this is a post from someone else:
Thought I would report my finding with this set. Maybe someone else is experiencing the same problem.
The set would turn on with no picture. No high voltage - no raster. By turning up the volume, you can hear some noise in the speakers. This set has many fuses and they all checked out ok.
I located some schematics on the net for the previous generation set - 40H80/56H80. I could not find any site with the 50H82 schematics without paying. The 40H80 seemed to match the 50H82 fairly closely. I checked the horizontal output transistor with a scope and found no signal. I traced the signal back to a board on the signal schematic called the DPC module. No HOT signal was being generated by this module. Per the schematic, I checked the voltage supply pins at this module and found everything ok except pin 6 which is supposed to be +12V. I traced this back to the power supply connector and found voltage (pin3 of 8 on BB30). Since I got the set for free and I was feeling risky, I shorted the +12V at the connector to pin 6 on the DPC. I got a small spark and the set shutoff, but I could hear static which indicated that the HOT briefly same on. I shorted out the connection again and turned the set on. This time is powered up and came back to life. I've run the set for a couple days so far and it appears to be working great.
I may have gotten very lucky, or I may be shorting out something that is not supposed to be shorted. I would really appreciate it if someone who has the real 50H82 schematic could check the connection between DPC pin 6 and the power supply connector BB30. If this is a real connection, I have to assume that the trace burned out somewhere. It vias up and down all over the place and is very hard to follow.
Posted on Dec 11, 2007
Toshiba 19hlv87 blinking
It is going on protection mode. Change the power outlet to some other that works. Try changing the input device to something that works. If it does not work, try switching off the TV manually, remove the plug after switching off the power outlet, wait for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | Toshiba 19HLV87 19 in. LCD HDTV
Tv problem
Hi
Tell me the model no and brand name so that we can help u ya.
Turn off the tv for five minutes and then turn on.
thank you
Oct 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
My Toshiba T.V. wont turn on
It is on protection mode and showing error code. Try switching off TV manually, switch off power outlet, remove plug and retry after 48 hours. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
When i try to turn my tv on i hear 3 clicks then nothing else no lights no picture no sound it wont turn on
It's trying to go back home to Kansas...jk. It's in a "Shut-down" mode to protect itself from a possible short circuit in the power supply. Need to take it to a shop - could cause a fire.
Nov 15, 2010 | Toshiba 32WLT58 32 in. LCD Television
No picture, starts normally then shuts off. blue light stays on. replaced lamp, and still the same problem. toshiba 62hm196
If a tv turns off after being turned on It is enambling the safe mode to prevent greater damage. It has probably got a bas chip or sync switch on the power board.
Sep 26, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Red light keeps flashing tv will not turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 30, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba plasma 42hp95 tv will not turn on red led lights blinking
Feb 23, 2009 | Toshiba 42HP95 Television
I have 3 blinking lights and tv wont turn on
Nov 07, 2008 | Toshiba 42HL167 42 in. LCD Television
TV picture wont come on, led light blinking, we have sound
Jun 30, 2008 | Toshiba 36HF73 36" TV
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
Toshiba 55H70 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
