D32750T RCA 32'' tv where do I find a new .0106uf 2000 vdc capacitor it's grey box type with no manufactuer id or part number that I can find It had a bad solder joint and has burned away part of the casing and circuit board resoldered it and tv worked for a while now the flyback acrs so before I replace the flyback I need to replace the capacitor but don't know where to find it
    President:
  • 1,922 Answers
M.C.M electronics in OHIO
Posted on Sep 12, 2009
I recently bought a 100uf 450v capacitor to replace a 68uf 450v capacitor. Unfortunately there is no power being fed to the TV when plugged in. I was told by a local TV repairman that the uf rating...
The fault to your TV might not due to a defective capacitor. A higher capacitance valued capacitor, won't do nothing wrong. But as the capacitance value increases, the size of the capacitor will too increase. That's all. Check the fuse at the power supply regulator board. If it is found opened, make sure that something wrong with the power supply regulator board. Without rectifying the fault, never replace a fuse, as it will make things worse. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Akai LCT3201AD 32 in. LCD Television
RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Feb 05, 2010 | RCA L32HD32D 32 in. LCD HDTV
Exact Same Problem. TV turns on, sparks, then shuts off.
your most likely talking about clo31 which is a 0087 2000v box capacitor. You can get the replacement at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-box-capacitor-0087uf-2000vdc/cName/rca-parts
Jul 26, 2009 | RCA D52W23 52" HDTV CRT TV
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
Apr 05, 2009 | iLO IWT3206 TV
Rca w 52 w 17 wont stay on
thats the box capacitor. you can try resoldering it, but its most likely needing replacement if the leads have black around it. If you do need a new one you can get the box capacitor at the following link.
Jan 27, 2009 | RCA D52W19 52" Rear Projection Television
Link
I was referring to the links posted by Ekse. If you could send me the info you have, I will point you where the capacitors are.
My email is jah2mil@hotmail.com
Aug 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
32 RCA Telvision With Picture Stretch
Mis-shaped pix is often a bad capacitor in scan circuit or a bad
solder connect on a shaping capacitor lead...............T.
Mar 14, 2008 | RCA 32V420T 32" TV
Remote problem
http://remotefinder.rca.com/default.aspx?site=rca
The above mentioned is a link to the rca site for your remotes codes. I didn't see a direct tv satellite as one of the options under SAT. But the code for your TV should be listed (I would try the Phillips listings first)
Hope that helps!!!
Feb 23, 2008 | RCA Universal Remote Control
Where can I horz output for my tv?
You can get one from Here
http://www.partstore.com/Part/Thomson/RCA/237470/New.aspx
I would only use the original part. This site I gave you is for the original Horizontal output transistor. If the part goes bad again, or runs hot, the capacitors in the circuit or the flyback is bad. Good Luck
Jan 07, 2008 | RCA F32450 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
