Question about Kicker ZX1500.1 Car Audio Amplifier
My kicker zx series 1500.1 has no output thru the speaker ports
I have a kicker zx series 1500.1 and it has ni output from the speaker ports so i hooked up another amp to c if it was the wires but they all work so if there is any way to fix it plz let me know
  • 376 Answers
Ck ext fuses, then possible internal issue
Posted on Sep 13, 2009
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
I have 2 JL Audio 8W0's rated at 75 RMS. I had a MTX 280 Amp pushing them but need to replace it, what brand and size amp do you recommend for these speakers.
  • This Kicker Amp will compliment them JL Audios like nothing else. KICKER ZX Series ZX350.4 4 channels all rated @ 75 watts RMS. If it was me that would be my choice for a replacement amp.
http://www.amazon.com/KICKER-ZX-ZX350-4-Amplifier-4-channel/dp/B000ENSSPM
Regards, Tony
Apr 29, 2011 | Car Audio & Video
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
Hi, I currently have the following Kicker Amp's.\r...
it depends, sometimes if your speaker is wired, if you have two dual 2 ohm subs and wire them in series ( +to+ -to- ) then they will wire down to .5 ohms, in which your amp is not stable other possible problems may occur if you wire these amps together to power one or two subs
May 18, 2010 | Car Audio & Video
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
My amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
Mar 20, 2009 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Srt 8 factory kicker system
try running the cables trough a crossover & u can run what u want to what speakers u want
Aug 09, 2008 | Kicker 01C8VR4 Car Subwoofer
Wiring
provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at sicaudio@msn.com , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Jun 25, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker ZX1500.1 Car Audio Amplifier Logo
332 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
