Question about Kenmore Elite 45986 Front Load Washer
Washer wont fill up - Kenmore Elite 45986 Front Load Washer
  • 6,784 Answers
HI. I recommend testing the inlet assembly for faults.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
Now, if the valve assembly passes the test stated above, and is functional, this will point to a failed control sector. replace the main control board or timer module in this case.
Posted on Sep 12, 2009
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont initially fill. all other operations
Check the screen on the inlet hose from water fill. If not, it is the timer that you set (it's not functional)
Jul 08, 2009 | Kenmore Washing Machines
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Washer fills up but wont spin
roof, if it fills and just sits there it could be the pressure switch, grab the end caps on each side of the consol and pull them off. Remove the two screws under them and flip the consol up. On the left side you will see the pressure switch with a rubber tube going to it. Get yourself a piece of tubing about the same size in diameter. After the washer fills, remove the tube from the pressure switch and blow into with the spare tubing. If the washer starts agitating, the pressure switch is the problem. Catriver.
Sep 29, 2007 | Kenmore 13202 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
