Question about HP (F5101B) External Floppy Drive
HP DRIVERLESS USB FLOPPY DRIVE F5101B
I have 2 HP laptops #1 8230 w/ XP media center and #2 DV4340 w/ XP professional. Drive loads fine on one media center laptop but crashes when pc detects new hardware and continiously reboots on DV4340 w/XP professional.
  • 211 Answers
Update your laptop chipset driver and check for broken usb ports.
Posted on Mar 12, 2009
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Hi, I got a free HP compaq desktop, the small ones, is 2.66hz it was working fine, but i don't have the password for the administrator in a xp pro, so I just reinstall a new copy of XP but now this...
please load xp again and press f 6 when you see it on the screen to load sata devices .
sata softwares and drivers are required in certain computers to load windows so while loading you will be asked to load those drivers through a floppydrive, so u must have
1)sata raid drivers (according to the hard ware installed in hp.)this piece of hard ware will not allow xp to boot if you dont give its drivers through a floppy drive(during installation and setup of windows.
so u must now have
1 floppy drive(usb)
2 a floppy disk with sata drivers
3)usb port to attach the usb floppy drive
after loading xp you will see xp running trouble free.
a easy solution is to load vists and the drivers are already there in vista cd.
Sep 19, 2009 | Computers & Internet
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
About harddisk
If this is a newer system, this issue is the XP CD you are using doesn't have the needed hard drive controller driver it needs to see the Hard Drive.
Because this is Windows XP, you have only 2 options to resolve the issue. XP will only load a controller driver during install from one of 2 locations. Either a floppy diskette drive or from the XP Cd itself. XP has controller drivers for most systems available at the time the CD was burned, but newer systems, especially ones with SATA hard drives do not have supported drivers in XP CD images. You options are as follows:
  1. Connect a USB Floppy Diskette drive to the system, download the needed driver (If one is available) copy the extracted driver files to the root directory of a floppy diskette and put the diskette in the Floppy drive, then boot the XP CD again. The driver should load automatically if the floppy is in A: Drive when you boot to the CD.
  2. The second option requires slipstreaming the driver (Same one downloaded to a floppy in 1) into the XP image. (This takes a good bit of knowledge in bootable cd creation)
If all this seems to be quite the hassle, then install Vista,
Feb 17, 2009 | HP Computers & Internet
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
USB external floppy drive
In windows XP and later the USB mass communication driver are in built, so you can use these devices like USB Floppy drive, USB HDD, Memory card, flash memory etc...
But before windows XP Microsoft did not supply the driver for USB mass storage devices. So, in your case you have to install the Driver for your USB Floppy drive, then you can use this drive as Floppy drive but after complete boot of your Windows 95.
If any problem or more question Just Ask me
Thanks
Iqbal
Apr 07, 2008 | HP Compaq Business Notebook NX9010
Saving on cd
Please repeat your question in other words. I cannot understand your QUESTION.
Jan 01, 2008 | HP (F5101B) External Floppy Drive
Windows instaling problem
When you disable for installation it normally does not work correctly when enabled again. Go to Hp's website and download the SATA software. You will need a floppy drive. The driver for it extracts to the floppy. If your laptop did not come equipped with a floppy you will have to use an external usb floppy. No off brand it has to be a name brand. Normally the generic floppies do not work. Once you have the software extracted to the floppy. Boot the computer to with xp cd. When the blue screen displaysa message accross the bottom with say "Press F6 if you need to install a third party SCSI or RAID driver. The computer will read the floppy and select one of the choices preferably windows default.
Hope this helps you
Dec 28, 2007 | Computers & Internet
HP (F5101B) External Floppy Drive Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
