Question about E-Machines eMachines Desktop PC
Can i install memory replacements from my old pc to the new one, they both say 520 megs ddr?
    President:
  • 1,996 Answers
To be on the safe side, use the crucial memory advisor here to look up both systems and see if the memory is compatible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 12, 2009
    President:
  • 2,600 Answers
To get a correct answer to this go to www.crucial.com and put the model of each computer in the search box and take note of the memory type, including pin number and frequency range. This way you can compare the memory that is specified for the models you provide.
Where can I get DDR RAM for my old PC?
You can buy them new or used on E-bay also I have seen them in my local cash convertors and Cex shop.
Mar 27, 2017 | Chips Computers & Internet
I have the HP Pavilion a1330n computer, I just installed 4G of memory (4 X1G) to replace my previous 1G (2 X 512). The memory specs are correct but every morning the computer has a black screen and I have...
NO OS stated, Blues screens you mean the BSOD with the halt? statement on screen? i bet yes. (with words on blue screen)
words matter.....
Bought new memory or old?
no, (to supposed) yes, to , back to beginning done wrong or luck bad.
so put back the old RAM, does that work.?
or use just 1 stick of old ram. ? 1 by 1.
then repeat, new ram 1by1,
see? one stick is bad, if it all ran perfectly before you touched ram.
buying RAM for such and old PC is not easy.
step1:
first ASK HP, you asked now at yahoo, why here, and not HP>?
but HP long long ago retired the A series.
per HP pages. here
https://support.hp.com/us-en/retired-products
personally I do go the used PC store and buy $20 PC vastly newer.
sure would, but lets follow the rules for yours, step by step
step 2, (1 was hp , no support)
next is to lean what Memory was uses and what the processor spec is on the same,
the mobo is 2005 era. (as old as) 12 years ago...
its not Intel, its Athlon 64 (S) 3800+ 2.4 GHz
if it was intel , the intel chip drives the memory with its MMC
its not.
ASUS made this mobo by HP contract.A8AE-LE
hp name is: AmberineM-GL6E
max mem
4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
PC-3200 MB/sec , speed ( not slower !) faster ok.
184 pin, DDR SDRAM
Dual-channel memory architecture
4 x 184-pin DDR DIMM sockets support unbuffered non-ECC 4 GB 400/300 MHZ DDR memory modules
page 7 is sparse in your manual.
https://www.manualslib.com/manual/721818/Asus-A8ae-Le.html?page=7#manual
the Athalon 64 has an ON DIE mmc, memory controller
this sets the base limits of all possible memory.
the memory speed is not by FSB, speeds
simpler terms, the memory is always running at a set fraction of the CPU speed
this chip has the advantage for running , cleaner DDR signals.
that other FSB designs.
what that means , to the user more memory choices.
I see this maker selling memory , a top maker,
http://www.crucial.com/usa/en/compatible-upgrade-for/HP-Compaq/pavilion-a1330n-series
test the sticks all 1 by 1,,, one good way to test it is run fast games.
DDR stick density rules and numbers and types of memory pre stick and pre side can cause problems on old processors.
I could not find the Athalon 64 rules on this, AMD can tell you at there site but im too lazy to look it up..
best is to let Crucial or Kingston guy you , here. for SURE>
Jul 13, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
I put new pc 133 ram into my compaq 5868 computer. It had 512 meg and I upgraded to 1 gig. But when I installed the new ram, The computer locks up. It starts the Memory test on start up, but locks up...
Sorry but I think that may be a bit much memory for that motherboard as described at the following links:
http://www.memorystock.com/memory/CompaqPresario5868.html
http://www.memoryupgradecompany.com/memory/CompaqPresario5868MemoryUpgrade.html
But I may have looked up the wrong PC, so the easiest way is put the old ram back in, get it running, then go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER option.
It will tell you exactly how much RAM you have currently, what type it is, and exactly how much more you can put into it. It's free and real handy and quick.
Good luck and please post back if this helps at all.
Jan 26, 2011 | Compaq Presario 5868 (143492-003) PC...
Removed 256 meg card, installed ddr2 1gig card. Computer would not start.
Old system!
Up to 2GB DDR are fine, but you tried DDR2, which it can't handle. Get the right kind of memory (just DDR, not DDR2 or DDR3) and see if they don't get along better.
Jan 03, 2011 | Dell Dimension™ B110 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I want to now which ram is used for dell latitude 640, latitude 520, latitude 430, latitude 420 and inspiron 2200 is it ddr2 or ddr1 and max capicity for upgrade
Here are the max memory and speeds:
Lat C640 is Max 512M per stick DDR-266 (PC2100) or DDR333 ( PC2700 ) for a total of 1024 Meg
Lat D520 is either 2 or 4 Meg total. DDR2-667 ( PC2-5300 )
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.Maximum memory for systems with the Intel 945GM chipset is 4096MB, maximum memory with the Intel 940GML chipset is 2048MB
Lat D430 has only slot with a Max of 1 Meg. You can use DDR2-667 (PC2-5300)  or DDR2-533 (PC2-4200)
Lat D420 is a max of  1.5G    . Use 1GB DDR2-533 (PC2-4200)
Inspiron 2200 is one slot with a max of 1280 Meg. recomended is 1GB DDR-333 (PC2700)
Here is a link to find almost any memory you need:
http://www.crucial.com/index.aspx
NOTE:
When mixed speeds in the same PC, the memory will run at the slowest speed installed or the highest speed allowed by your system, whichever is slower.
Good Luck
Dec 17, 2009 | Dell Latitude C640 Notebook
I removed the old memory and installed 4 1GB cards and the computer doesn't work? Help.
Adding new memory can be tricky. First the new memory has to be compatible with the motherboard.
By that I mean, you need to know how much memory the motherboard can max out at.Can it take only 2 GB or 4GB etc. And it has to be a match to what memory speed your motherboard can handle. If your motherboard takes DDR than you must put DDR in, if it takes DDR2 than you must put DDR2 in. Look at the old memory, and try to match all the numbers you find on it. Than look up the memory specs for the motherboard to find out how much it can take.
Any computer will not operate corecctly if the memory is the wrong kind, or installed wrong.
Jul 02, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Computer wont boot after memory upgrade
when working on computers you have to be carefull to ground your self before touching the inside of them. when installing memory you dont need to unpluge everythinf just the main power cord on the back of it.the blinking green light means you have something no pluged in right,double check everything you unpluged make sure it back in the right areas.on memory the slots are mark 1,2,3,4
make sure if the memory is diffrent in speeds the lagger ons go first.the first to slots normally have to be the same speed and size ram.if that does not work let me know i can look into it for you.
Dec 15, 2008 | ASUS P5RD1-VM Motherboard
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
