Question about Garden
Height adjustment on my lawn mower
My new lawn mower has a height adjustment on each of its four wheels. My old one only had one lever to make adjustments. There are five holes on each of the rear wheels but there are eight holes on the front two. I'm puzzled! How do I line up the mower height/ Why is there different number of adjustment holes fron & back?
  • 16 Answers
Have the mower on a flat suface and adjust for the height you need on all four wheels then raise the rear of the mower by one hole to give clearance and reduce the loading on the blade
Posted on Sep 12, 2009
  • 3 Answers
Put it on a flat leveled surface and use a level and with a sharpie mark your clearance on your adjustments of all wheels ! 1 2 3 4 on all wheels !
Posted on Sep 02, 2012
How to set cut level
Hi Kyle:
If this is a push mower, The cut level is just about always set by adjusting the height of the wheels. There are usually little spring loaded levers that let you move the wheels up or dow.
SAFETY FIRST> NEVER try to adjust these with the engine running.
Apr 03, 2015 | Garden
How do I engage back the height adjust on my black and decker lawn hog
if there are no adjustments at the rear wheels install new wheels to accommodate mowing hieght
Dec 05, 2014 | Black & Decker Black and Decker Mm575 18"...
How do ichange cutting height on honda petrol lawn mower
There are loads of different arrangements - the most common is a lever sticking out of the read of the machine that adjusts the height of the roller, and 2 adjusters for the front wheels.
Oct 05, 2014 | Honda Garden
I have a Honda HRX217 versamower and I would like to know where the wheels should be for the highest height for my lawn, or should I buy a riding lawn mower to get more height. My lawn is dying with
Move the 4 wheel adjustment levers to the number 4 position which is all the way forward (towards you if facing the front of the mower) and that is the highest setting which is about 4" cut height. Each number for the lever position represents the inches in cut. In between numbers is 1/2" so in between 2 and 3 would be 2 1/2" cut as an example.
Aug 22, 2012 | Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust grass cutting height on
some old mowers you need to unbolt each wheel and move them to a different hole
Apr 21, 2012 | Garden
The hover fly mower sits on the grass, being that there are no height settings, it cuts quite low. Are there way's to make the mower sit higher off the ground in order to cut the grass at a higher...
Usually all mowers have height adjustments of some kind. Look around your front and rear wheels, if you have a number of holes drilled into the deck ,these are your adjustment holes.You would unbolt the wheels and put them at the height you would like.
If as you say there is no adjustment, I would say buy new wheels that are an inch or more bigger than your present wheels and install them in place of your old wheels. If you go to any local dealer they will be able to help you with your problem.
Jul 03, 2011 | Garden
Black and decker 18 inch flip over handle electric lawn mower cat #8019 don't know how to adjust height it is cutting way too low
There is no height lever on this simple mower. To change the height of cut, the wheels themselves must be moved up or down. First, unplug the mower. Turn it over on its side. You'll see that the wheels attach to the frame with simple bolts, and that there are two open holes at each wheel (three holes at different heights altogether, but one of the holes is occupied by the current mounting height of the wheels). Undo each bolt for all four wheels and move them to a new position. Note that the wheel-mounting holes are drilled 5/8-inch apart from each other. If you want to add another hole there is room on the sheet metal to make a new hole for each wheel, and this would put the mower body and blade very high off the ground, if used. You can make that new hole for each wheel with your electric drill. But I think your mower is probably set to the lowest of the three holes, so see first if moving the wheels 5/8-inch higher is better for your lawn, and, if not, then use the 1 1/4-inch higher set of holes on all four wheels. Make sure to move each wheel to the same height hole! Good luck, be safe. --Joe, Tucson, AZ
Apr 30, 2011 | Garden
MODEL 5521 RS
hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks mossieirwin@hotmail.com
Oct 14, 2008 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
438 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
