My Onkyo TX-SR700 AV Receiver shuts off about 10 seconds after I turn it on ?
  • Robert Cardenas Sep 12, 2009
    My Onkyo AV Receiver TX-SR700 goes into protect mode and turns off about 10 seconds after i have turned it on even after i disconnected all speakers from receiver. I solder and have test equipment but don't know where or what to start testing first. If you could help me out in that department it would be appreciated. Thank you....
  • 10,594 Answers
Please remove speaker wires from receiver and turn it ON, if receiver still goes to standby that means it got problem in amplifier output section and protection circuit gets activate to turn it off.
If removing speakers solve turn-off problem that shows any of speaker is bad, connect speakers one by one to find out what speaker causing protection circuit activation.
And if receiver has problem with internal circuit, a tech would be fine to diagnose that kind of problem because it is not user level repair as it requires testing voltages in output circuit of receiver and also requires soldering work to replace defective parts.
Thanks.
Posted on Sep 12, 2009
  • 3,051 Answers
Hello there
Have you tried unplugging the receiver from the power outlet and plugging it back in? Does it reset? There might be a command to reset the settings in the manual. if you dont have the manual you can download it at the manufactures web site ok?
hope that this is somewhat helpful
best regards michael
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Cannot find code to set my cable remote to turn on/off my receiver
The Remote Code 1789 will both turn ON and also turn OFF the Onkyo TX-SR605 AV/Receiver. Many codes will either turn it on or turn it off, but not both. Code 1789 will do both.
Oct 19, 2010 | Onkyo TX-SR605 Receiver
Stanby light for zone 3 is on , cant shut down the volume, i need to reset the receiver, any steps i have to follow?
To reset the Onkyo TX NR3007 AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. “Clear” will appear on the display and the AV receiver will enter Standby mode.
Thanks for using Fixya.
Good Luck and have a nice day.
May 27, 2010 | Onkyo TXNR3007 91 Channels Receiver
My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
Oct 16, 2009 | Onkyo TX-SR700 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Clicking noise from Onkyo TX-SR606 during television broadcast
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Jan 04, 2009 | Onkyo TX-SR606 Receiver
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
Mar 25, 2007 | Onkyo TX-SR700 Receiver
333 people viewed this question
 Grubhead
Grubhead
