Question about Homelite Mighty Lite Lawn Trimmer
Home lite 20002a won't stay running
My homelite UT20002A won't stay running. I prime the pump and it will start and stay running for a few seconds, but then stops. The pump bulb is also dry at this point. I am suspecting a fuel flow issue somewhere, but don't know where to start. I am pretty handy, so i don't mind trying to fix it myself.
thanks in advance for your assistance.
  • 138 Answers
When you use the primer bulb does it pull fuel out of the tank and fill the carb and any extra returns to the tank ? I am sure this is the case since you can get it to start and then it runs out of fuel. It sounds like you may have a dirty filter in the tank or the diaphrams in the carb are stretched from age or dried out from sitting either way the first thing I would check / replace is the fuel filter and if this doesnot correct the problem i would then rebuild the carb. Good Luck i hope this helps you out
Posted on Sep 13, 2009
Low fuel pressure. Won.t start but pump run.s then shuts off
Pump is only supposed to run a few seconds to prime system with key on. Should run in start position, but check for restricted fuel filter and for bad fuel pressure regulator.
Jul 14, 2015 | Cars & Trucks
Will not stay running
Not adjusted properly.
Dec 29, 2013 | Homelite Garden
Starts but won't stay running
Turn off all your accesories and turn the key forward, but dont start it. You should hear the pump kick on for 2-3 seconds. Prime the system a few times then start it. This will narrow your diagnosis
Dec 06, 2012 | 2002 Ford Escort
Motor starts but won't keep running
if it has one of them little plastic bubbles to prime it then i think your bubble has a pin hole it or something as its sucking in air causing it to loose the fuel supply and then it stops
Dec 11, 2011 | Homelite Garden
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 13, 2010 | Homelite Mighty Lite Lawn Trimmer
HOMELITE EXPAND IT 26VT WON'T RUN
Well if you are missing parts?...No. How could anyone from where we sit. But the fact that it starts with starting fluid is a great sign however. First off, Fresh gas/oil mix is A MUST! No getting around that. OK first, when you pull the throttle (Give 'er gas) does the little lever at the carburetor move back and forth at all? if yes, then what happens when you hit the primer bulb? Does it push/**** fuel from the tank? (My homelite spits fuel out to the ground when I prime the bulb, most spit it back to the fuel tank however) See if priming it moves fuel. You should see a trail of bubbles in the fuel tubing. You have to see if you are getting fuel at all first. Then does it maintain the prime? If not? Then the primer bulb will usually remain empty. A good prime should always show a half full or 100% full bulb at all times. Let me know what we got so far.
May 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite 25cc trimmer. It will crank but will not run but a few seconds? Have cleaned Carberator and replaced Gas.
you either have one of two things wrong. my first guess is that you have a crack or hole in one of your fuel lines causing it to not get enough fuel. the reason it will run for a few seconds is that you pump a little fuel in when you prime it. my second guess is that you have a very plugged fuel filter or something obstructing the fuel lines. take a look at the lines all the way very closely for cracks, as this is very common in seasonal tools like these. let me know if this works. if not, i will help you get it fixed. thanks.
Mar 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Loss power Trimmer HomeLite UT20002A
Check the muffler for obstructions. Remove the muffler and check the exhaust port sometimes they are near plugged. If so remove all the crud with the cylinder in up position to prevent getting carbon in cylinder. Trimm to adjust Turn both L and H set screws clockwise until they bottom the back each one out 1 and 1/4 turn. This should allow you to start the trimmer. Then rev to max rpm and adj. the H screw to max rpm. Then set the idle with the L screw with good idle without string head turning. Then when throttled it should do so without hesitation. Once this is set you may have to fine trim the H screw for max rpm again.
Mar 12, 2008 | Washing Machines
Homelite Mighty Lite Lawn Trimmer  Logo
556 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
