Question about Refrigerators
Where will I find the model number on a Kenmore side-by-side
  • 5 more comments
  • rvautard Sep 12, 2009
    Thank you,
    Kenmore model #58242890
    S# SH3940848
    MFG 09/98
    SECOND RESPONSE:
    Model number 58242890
    S# SH3940848
    MFG: 09/98
    -- YES -- this is my third reply to you. My question on how to remove the ice maker has not been answered.
    I responded twise with the numbers off of the frig.
    Thank you.
    I took out the screw and the ice maker will not move. Guess I'll have to pull harder.
    The ice maker is making ice, but when it rotates to dump the cubes it gets hung up with the ice cubes straight up.
    Any suggestions on a fix/repair?
  • rvautard Sep 13, 2009
    The ice will rotate about 90 degrees placing the cube vertical, and then stop rotaing. I defrosted the freezer (all day Saturday) allowing the ice to turn back into water. The ice maker has not rotated the ice cubes since.
  • rvautard Sep 14, 2009
    Thanks for all of your suggestions. I printed a parts breakdown from SearsPartsDirect.com. I looked at all that I could, and everything seems in order.
    I have given up!! I just purchased a new ice maker off e-bay for $50.90 (including shipping). This is 50% off retail (repair clinic $109.75. Sears $118.69. Partselect $114.60)
    Thanks again.
    Great service and sound advise. Thanks
    President:
  • Refrigerators Master
  • 1,714 Answers
Model Identification
Locate product information on the nameplate, found in
upper left corner of Fresh Food section. Record the
following information: Model Number, Manufacturing
Number, Serial or S/N Number, Date of purchase,
Posted on Sep 12, 2009
  • 3 more comments
  • Craig Butler
    Craig Butler Sep 12, 2009
    Is there anything else I can do for you? If not please close and rate my help ...thanks!
  • Craig Butler
    So sorry, this is the first time I have seen anything about the ice maker.All I saw in the post was 'where is the model number located.
  • Craig Butler
    Turn water supply off to refrigerator. Remove screws to ice maker and pull forward. You will see the water line connection at that point. Check water line and see if you can see where it's leaking. If necessary, turn water supply on while ice maker is pulled forward to find leak.
  • Craig Butler
    The ice rack is heated briefly to drop the ice into the bin. Then the auger motor can move them forward.If the ice is not dropping, does it try, or just sit on the ice rack? Get stuck while dropping...?
  • Craig Butler
    Craig Butler Sep 14, 2009
    There is a door switch to the ice bin, see if you can find the door switch for this ice compartment and check it. The ice drop function is stopped. Also, see if you can cancel ice by turning it off and see if the tray will rotate back. The sensor for the ice maker may be bad, see if you can find the switch for the 'ice full' also. Give everything a good look and see if you see anything that does not look right.
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Where is the water filter on a 1998 kenmore fridge
Here is where the confusion begins. When Kenmore says their model number, it is different than OEM numbers or original equipment manufacture's number's. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze Once you find that 363.235698 example you will be well on your way!
May 05, 2011 | Kenmore 52642 / 52644 / 52649 Side by Side...
My Kenmore refrigerator makes a clicking and clacking sound
Sounds Like the overload and start relay, yet I need a little more information to get the part number. See these notes> Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze -->
May 01, 2011 | Kenmore 53693 Side by Side Refrigerator
The ice dispenser when pressing it in with a glass does not work, it doesn't seem to push in far enough to activate the ice dispenser but I can reach in with my finger and pull on it and it then will...
Yes the number you are searching for is called an OEM number or original equipment manufacture's number. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze
Apr 21, 2011 | Kenmore Side by Side Refrigerator
Need a replacement shelf/drawer for my Kenmore fridge
Good day
For starters you can try here. It may list the model number.
Be sure the model number is correct.
On Kenmore machines the model number always starts with a 3 digit number followed by a dot and then the balance of the model number. For example 106.12345678
http://www.appliancepartspros.com
Jul 18, 2010 | Kenmore Refrigerators
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
