I've replaced the PSU of my Dell Dimension & I can't boot
I've replaced the PSU of my Dell Dimension 8300 by a solytech d460 atx, with a special cut on the back side so that the power switch can fit.
when i push the power button of the PC, the PC is trying to boot, but after the XP logo, the PSU turns Off. I must switch it Off. compatibility problem between the Dell's power button connected to the MotherBoard, and the PSU ?
After replacing by the original PSU, everything's OK.
I don't undersand.
  • 1 more comment
  • thierry_loeu Sep 13, 2009
    I'm going to check the new PSU plugged to another PC this monday, and i'll check the different voltages
    thanks a lot
  • thierry_loeu Sep 14, 2009
    I've checked everything today with an other computer & every pin of the PSU have ground and voltage good
    I don't understand why (with the new psu) the PSU stop running suddenly when i boot,and why i must switch it "OFF" then "ON" to get my front power button in function again
    President:
  • 2,600 Answers
I have done countless transplants with over the counter PSUs in Dells, HP and many other OEM rigs without incident. I would suspect you have a faulty PSU. Just make sure you are getting one with a little more power than you currently have and try to match the design spec as much as you can. If you can find one without the aux. power switch then that's even better, but it makes no difference.
Posted on Sep 12, 2009
Dell 8300 failed at checkpoint krst
Try F12 or ESC or Del. Google search the error message by Make and Model of desktop.
Mar 04, 2013 | Dell Dimension 8300 PC Desktop
My dell dimension b110 quit working one day and just flashed an amber colored light. I was told I need to replace the power supply. Is any 400W 20+4-pin ATX PSU w/SATA compatible?
Yes, just make sure it's ATX (not ATX mini etc but you'd see from the connector anyway) has the right motherboard connector and all other connectors. Also I'd go for a 450W as if your 400w died it may have been from a power surge that a 450W or higher would handle better.
Oct 29, 2010 | Dell Dimension™ B110 PC Desktop
How do I reformat a Dell dimension 8300, it will not do anything after inserting the operating system disk
You need to make the DVD drive the first bootable device.
F2 on boot up should take you into the bios, it should say on the first screen as you boot what key takes you into the bios/setup.
Change the boot settings to allow the dvd drive to boot first.
It should now say press any key to boot from cd/dvd when you put your installation disc in
Sep 04, 2010 | Dell Dimension 8300 PC Desktop
Activating mic on Dell dimention 8300-- I connected mic then went to sounds, audio devices then volume and advanced then option & properties & record. Nothing? Please tell me what I'm not doing....
Make sure that the drivers are loaded properly, Start>Right-Click "My Computer">Management>Device Management. If you have any splats under your Device Management you may just need to reload the driver. Dell Dimension 8300 drivers are here
http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_8300
And also make sure it is plugged into the pink jack.
Jan 27, 2010 | Dell Dimension 8300 PC Desktop
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
I cant find sound driver
Suggest you download, and install the Audio driver, for the Dell Dimension 8300.
This is Dell Support and Downloads, for the Dell Dimension 8300 Desktop PC,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Sep 04, 2009 | Dell Dimension 8300 PC Desktop
PSU
You can try to rearrange from ATX form to dell form.
Here is ATX arangement
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
and here is dells arangement
http://www.jdresearch.com/icon/shark20pin.jpg
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
