Question about Sony KP-65WS500 65" Rear Projection Television
Sony 7 blinks
Wondering if you or any tv expert can answer my entry on dec 8th 2007.tv in same status as before.A local repair tech is leaning to replace my power supply? I feel i will become a victum of a fraudulant repair estimate.Can anyone help or give me any pro advice? thanks
tony p
  • 1 more comment
  • niker Jun 17, 2008
    I have a Sony KP-65WV700. Standby light blinks in interval 7 times. Turns on to blue picture then it fades to light blue then goes black. Sound continues to work
  • pistonesal Nov 14, 2008
    I have close to the same problem . I get 10 blinks. I have a KDP-51WS550 and have repalced Q8013 and Q8014, and ID 8005 and still have the problme. I am lost at what is going on. Can you please help?
    Thanks
    Sal
  • pistonesal May 11, 2010
    I checked the resistor and all measure OK.. Please help so more..
    Thanks
    Sal
    President:
  • 4,402 Answers
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Posted on Dec 11, 2007
Where inthe philippines is your service center where can i locate or found your place? cause you need to see my camera
Sorry, but FixYa is a web-only information resource and does not actually undertake the physical repair of any products at all.
I suggest that you find a camera repairer local to you or you may wish to contact Sony using the following details (Sony purchased Konica Minolta):-
Sony Philipines, Inc
8th FLOOR, Net Square Building
3rd Avenue Corner 28th Street Crescent Park West,
Bonifacio GLOBAL City Taguig.
Metro Manila, 1634
Philippines
TEL: +(63) 2-878-7600
FAX: +(63) 2-860-3398
WEBSITE: www.sony.com.ph
Alternatively, post another FREE question on this website describing your problem and Friendly FixYa Experts will try to assist you. Please bear in mind that answers are provided by unpaid volunteers, so just like you we have to earn a living, do household chores and umpteen other normal things, so answers may not always be as fast as you like.
If you pay for a subscription to FixYa's Premium service, then you'll get faster responses from selected Experts who have a small financial incentive to solve your problem to your entire satisfaction. You don't pay for answers which don't fix your problem, and the Expert is only paid for the fixes you're happy with.
Hopefully, you have found my answer to be of some use. All that I ask in return is that you take a moment to rate my answer.
Jan 22, 2010 | Konica Minolta DiMAGE A200 Digital Camera
Turns off and blinks 7 times
The 7 blinks in sony tvs(sony errors codes) usually indicates a high voltage shutdown(tv has exceeded 33k volts) . The power supply regulation and/or the horizontal circuits may be at fault.Unless you have a good knowledge of tv circuitry you might need the help from a local tv repairman. Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion.
Dec 03, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KD34XBR960- NO PICTURE blinks 7 times. Thanks
Horizontal Deflection
Stopped
7 times 7:0 or 7:1 • No picture
Horizontal Defl ection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
IF YOU WANT TO DOWN LOAD A FREE SERVICE MANUAL OR TECH MANUAL FOR YOUR T.V. HERE IS A SIGHT THATS TOTALY FREE
http://www.schematicsforfree.com/archive/dir/Sony/Video
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDF-60XS955 Wega Tv when powered on displays video for 10 seconds. Then the video disappears, screen goes black, the power/standby light blinks green for 30 times, video comes back on and the llight...
Since you have not replaced its lamp yet. Symptom shows that TV lamp is weak and consume more then required current and causing error of shut down and reboot.
Please replace lamp. Lamp light will lit when lamp would be dead, currently it is weak.
Mar 18, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony 36brx800 shuts off on own
As a TV tech the simple answer is no! If you were a well qualified electronics tech but just not used to TV's then the answer might be a very weak 'maybe' and that's if you had a TV tech talking you thru the whole process on the phone.
shutdown probs can be the power supply, bad solder joints, or also very likely the high voltage power supply. Meaning the area where the TV generates upwards of 30 thousand volts!! The set has overvoltage protection that makes sure that things don't completely fry, catch on fire etc.
Ya really need special training to avoid getting zapped with tazer like volts or worse! Sorry but safety says better stay out of this one!
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Standby blinks 7 times
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
May 25, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
36 inch sony wega trinitron
I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
I will buy a new tv now--definitly not a Sony.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-65WS500 65" Rear Projection Television Logo
749 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
