Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 paper tray is open about 1-1/2'' and is stuck and won't come out or go back in. There is something locking it in place. The spring-loaded paper bed is in the up position and won't move. How do I release it to get it out? Thank you.
1. I took bottom metal support bracket off, probably didn't solve issue.
2. Adjusted paper width guide, on gears, when I did that, spring loaded piece that paper lays on released, pushing down, and I was able to remove paper drawer.
Posted on Sep 13, 2009
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
BROTHER MFC 8440 ERROR "NO PAPER"
Check the paper tray adjustable guides inside the tray; the guides need to fit around the paper snug, when re-inserting the tray if the rear guide is back too far the paper may be shifted towards the front of the tray out of range of the paper sensor so it thinks it's out of paper. I service HP LaserJet printers and most of the time this is the problem. Hope this helps.
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Paper jam How do I correct this? There is no paper along any pathway!!
does it ever reset by opening and closing front door? if not, there could be paper stuck in fusing area behind rear door. open and inspect. if you see no paper, pull drum unit out and locate open slot in the bottom, center of drum unit. could be a small scrap of paper in that slot.
hth,
razors
Jan 28, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper Jam
sometimes the paper gets jam internally if the small piece of paper is just not letting the gears to move fluently this problem cad occur.for resolving this the whole printer needs to be opened and cleaned part by part.
but sometimes unplugging the printer from the main power outlet for sometime the replugging it again resolves the problem.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Hello, I have Brother printer MFC 8440.I keep getting mesaage that i have paper jam. I checked all places and there is no paper jam.How can I fix that problem?
It's possible there is still a very small scrap of paper left. If you have a can of air blow it in and try to dislodge it. If that doesn't work try to unplug it wait a minute and plug back it.
Brother MFC 8440 Automatic Feed Malfunction
you need to reset it from the printer setup menu
Nov 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Can't make a copy
1: power off and power back on. 2: see the original manual for resetting to factory defaults.
May 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
121 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
