Question about Refrigerators
I have the part to replace the defrost, timer on my Kenmore 596.72824200. I just need to know if the repair is in the refrigerator behind the light or if it is in the back of the refrigerator. I am getting conflicting information.
  • mwheeler36 Sep 12, 2009
    I was told this was an easy fix by another expert. I hope it really is. The answer I received kind of concerns me.
  • Refrigerators Master
  • 22,326 Answers
The sensor is either in the freezer compartment or behind the rear internal cover and the control switch is where the light is .Then you have remove the covers to extract the end of the sensor ,this is where the fun starts and the naughty words begin ,best of british with it anyway from spain ?? The rear panel if its a frostfree model or in the freezer if its a conventional fridge .Honest the amount of people who throw these things away just because the thermostat packs up is criminal ,but with repairman wanting a fortune in call out fees often its cheaper to buy a new one or do it yourself....my hat is off to you
Posted on Sep 12, 2009
Refrigerator part of coil freezing up, what would be the problem?
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Jul 25, 2013 | Refrigerators
We have a top freezer Kenmore refrigerator which is at least 12 years old. It is cooling intermittently. It will cool everything just fine for three or four days and then it will defrost completely.
That sounds like your defrost timer is beginning to failm moving slower and sticking into the defrost cycle longer than it should. WR9X520 Defrost Timer
The defrost timer can be found inside and behind the control panel where you adjust temperature. Item 648 in this diagram is your defrost timer=> HERE Let me know should you have questions I will be here to answer them, Thanks Sea Breeze
Nov 15, 2012 | Kenmore Refrigerators
I have a Kenmore model#363.50242000.Its a side by side, every couple of weeks, the back wall on the freezer side gets a coat of ice and the temp start to increase. I have to manually defrost it overnite to...
Hang in there I just may have the solution. There are 3 major components of your defrost system. Behind that rear wall is your defrost heater and defrost heater part=> WR51X10031
Te most likely problem is the defrost timer=> WR9X489_defrost_control and here is where heater and defrost thermostat are located=> 363.50242000 Freezer Section First you need to look inside your fresh food compartment and Click Here=> Control Panel just behind that panel is a defrost timer see if we can force defrost by using a flathead screwdriver slowly clockwise until the compressor and fans stops then after about a minute defrost will begin and after 25 minutes the timer should turn the refrigerator and fans back on. If not replace timer if yes the come on and still no defrost the we need to go into the freezer and replace the defrost heater and defrost thermostat, please rate this solution, Thanks, Sea Breeze
Mar 12, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Need a service/repair manual for a Kenmore refrigerator.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 4 on this diagram is your timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=1069608210&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&diagramPageId=00003&componentDescription=COMPARTMENT%20SEPARATOR%20AND%20CONTROL&documentId=00050440&backToLink=Return%20to%20subcomponent%20list
Aug 13, 2009 | Refrigerators
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not defrosting
The reason it is not defrosting is one of three things. First and most likely is that the Defrost Thermestat (aka BiMetal) is open and needs to be replaced, secondly it could be that the defrost timer is bad and lastly the heater can be bad. The bimetal and heater are found behind the back panel in the freezer section. The time is usually located near the controls in the fridge section. I would need you entire model number to tell you exactly where it is. To replace the either part is fairly straight forward. With the full model number I can walk you through the easiest way to test each part.
Nov 01, 2008 | Kenmore 62232 / 62234 / 62239 Bottom...
Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Mar 30, 2008 | Refrigerators
Refrigerator Running Warm
It has a defrost problem.  3 things could be the problem.  1. Defrost thermostat  2. Defrost timer  3.  Defrost heater.  The timer is in the fridge section in the middle of the console behind the controls.  On that console you will see a little hole that will give you access to the timer gear that can be turned clockwise (slowly until it clicks) to put it into defrost.  Take the back panel off in the freezer.  Once you have put it into defrost see if the defrost heater comes on behind that panel in the freezer.  If it comes on then the timer is bad.  If the heater doesn't come on then it is most likely the defrost thermostat which clips onto the evaporator behind the freezer panel.  It's less likely, but it could be the defrost heater itself but it can easily be tested with an ohm meter for resistance.  Any resistance means it's ok.  Let me know if you need further assistance.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Kenmore 65812
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
