Question about Nikon Speedlight SB-800 TTL Flash
Why is my sb-800 melting my batteries?
My sb-800 melting my batteries, i was just using duracell AA's and i noticed the flash was overheating, so i checked the batteries and they fried.
    President:
  • 1,187 Answers
Thre is a non-repairable short in the capacitor charge circuit that puts a big amp load on the batteries.
May be repaired by Nikon service... but the electronics contain high voltage. Do not attempt to repair yourself and I wouldn't trust it even if Nikon repairs it. Why risk burning your camera and equipment!?!
--sorry--
Posted on Sep 12, 2009
Testimonial: "Thanks for the help, I guess I'll just have to deal with it and take it easy when going full power."
Two of my three Truth Cam 35's burn up batteries, and have gotten hot enough that it has melted the case. Brand new Duracell batteries only last a day or so.
Powered by 8 AA batteries
wierd
to burn them up so fast and melt the casing same time
did changing the settings make a difference
if not... would say its something about the cam
Primos Truth Cam 35 Review Decent Camera at Great Price
Nov 08, 2016 | Duracell Cameras
My SB 700 shows temperature after few shuts and when it's twisted
From the SB 700 manual page b8:
v Notes on continuous fl ash photography • To prevent the SB-700 from overheating, allow it to cool down for at least 10 minutes after 15 times of continuous firing. • When continuous flash firing is repeated in quick succession, the internal safety function adjusts the recycling time by up to 15 seconds. If flash firing continues, the thermal cut-out indicator appears on the LCD and all operations are suspended. (0E-31) Allow it to cool down for several minutes to disable this function. • The conditions under which the internal safety function is activated differ depending on the temperature and the SB-700 flash output level. Operation B B-8 Slide the battery chamber cover open while pressing the battery chamber cover lock release. Insert the batteries following the [+] and [-] marks. Close the battery chamber cover. STEP 1 Inserting the batteries Operation B B-9 1.5 V alkaline AA battery 1.5 V lithium AA battery Rechargeable 1.2 V NiMH AA battery Suitable batteries When replacing batteries, use four fresh AA-type batteries of the same brand from any of the following types: • For minimum recycling time and number of flashes for each battery type, refer to "Specifications." (0H-27) • Alkaline battery performance may vary greatly depending on the manufacturer. • 1.5 V carbon-zinc AA batteries are not recommended. v Additional precautions regarding batteries • Read and follow battery warnings and cautions (0A-19 - A-22). • Be sure to read and follow the warnings for the battery on the section, "Notes on Batteries" (0H-9), before using the battery. • The recycling time can be longer when lithium AA batteries are used because they incorporate a function that suppresses the output current when heat is generated in the batteries.
Nov 26, 2015 | Cameras
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nikon digital 1-800-645-6689
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
My sb will power on but i have no flash even when i hit the test button. I noticed it got a little warm then shut down when the problem first occured. Is it fried or fixable?
Are you using fresh batteries? Are they rechargeable batteries if so do a battery test maybe a battery is weak. With fresh batteries it still does the same thing then call Nikon 1-800-645-6689
Aug 28, 2010 | Nikon Speedlight SB-800 TTL Flash
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    SB-800 -3EV message after about 50 shots or so
    IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
    TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
    YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
    DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
    BERRIE SMITH CAMERA REPAIR
    bbmw@bellsouth.net
    Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
    15 MINUTE AA CHARGER
    Call duracell and explain your problem they will likely send you new batteries. They will tell you that yours are old.
    Duracell if the the USA (800) 551-2355
    Aug 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
    Nikon Speedlight SB-800 TTL Flash Logo
    265 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
