Question about Kenmore HE2 Plus Front Load Washer
My he2 leaks where the hose connects to the back of the tub. There is actually a hole where in the piece where the hose connects to. The hose will not cover this hole when shoved on all the way.
It was actually the overflow tube that was the problem. I plugged the hole using a small bolt and nut with a neoprene washer sandwiched on either side of the hole.
Posted on Sep 13, 2009
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Machine leaks water
The most common place for a front load washer to leak is in the bellow. This is the rubber piece right inside the door. Pull the rubber piece back and check for tears or holes. If there are not any holes then there is probably a hole in the hose that runs from the tub to the pump. Sometimes stupid things like bra underwire and bobbi pins get in here and tear them
Aug 25, 2012 | Maytag MHWZ400T Front Load Washer
Washer is leaking from door, the other day the rubber gasket between door and tub came off during use..we put it back on, but it still leaks
It sounds like you have a hose leaking.You can check the hose leaking by opening the washer door & inspecting the rubber boot that goes around the perimeter of the tubs. It is secured in place by two clamps.In order to check if the leak is underneath the washer tub you will first need to disconnect electrical power to the washer.Remove the three screws securing the toe panel to the front of the washer and remove the toe panel by lifting slightly and pulling forward.
Hope this helps.
Shane
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
Water leaks out of bottom of washer
The screw in the washer tub, is not a factor in this. I'm not sure what brand of machine you have, but several machines have a fill hose that connects to the outer tub of the machine. Sometimes when a machine gets loaded heavily, during the spin cycle items in the machine can actually knock the fill hose right out of the tub. Then when the machine trys to fill the next time, all the water runs down the outside of the tub and leaks out of the bottom of the machine.
Repair is to open up the machine. You'll need to remove the top cover and that will give you access to the hose/tub connection. It may be as simple as reinserting the hose back into the drum or you may need to replace it if it got too damaged and won't stay in the hole correctly.
If you need specific how to's on opening up the machine, get back to us with the make and model info and we'll be happy to help you open that washer up!
K
Aug 01, 2009 | GE Washing Machines
I have a Kenmore HE2 with a hole in the tub.
Any 2 part waterproof epoxy.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Removing a pressure switch (Kenmore HE2 Front Load Washer)
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2009 | Kenmore Washing Machines
Leaking underneath but all hoses are connected
When a washer is leaking, there are several areas where the liquid could be coming from.
If it only leaks during a spin cycle, it's probably caused by a leaky drain hose
Leaks on a front-load washer can occur around the door seal. This can happen because of a build-up of dirt and soap on the seal itself preventing a proper seal from taking place. Wipe the door seal carefully making sure that the edge of the gasket is clean.
Parts of a plastic bleach dispenser can crack or break off, causing a leak intermittently during the flush process. This is because bleach is a very corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust stainless steel parts..
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
Tub leaks are usually caused by a rotted tub. If this is your problem, consider buying a new washer. Sometimes a constant imbalance can be the culprit. This imbalance can rub a hole in the tub if it consistently runs off-balance. It may be possible to repair the tub with an epoxy kit. Tub replacement isn't usually very economical.
The main tub seal can also leak. This is located where the transmission and the outer tub in the centre. If this seal goes bad, it can be very difficult to replace.
Sometimes the water-inlet valve develops a buildup of mineral deposits and rust. To check this, remove the water-inlet valve and visually inspect the surface.
There is a cool product that is designed to help prevent water damage from a leaky washer. It's called a Washer Floor Tray This tray catches water leaks and prevents floor damage from overflows. This product is a must for upstairs laundries
Sep 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
106 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
