Question about Maytag Dryers
I have a closet clothes dryer with a grounded plug that has one prong perpendicular to the other. Can I just replace the outlet with one that will fit the plug, or do I need to add a different electrical power supply?
  • 30 Answers
You only noted three prongs: ground, vertical and horizontal, so I am guessing (since I can not see it) that you have a 240V 20 Amp plug on your dryer. There should be a number on the face of the plug that tells what type it is (my guess: NEMA 6-20). As long as you have a minimum of #12 (20 Amp) 3-conductor cord feeding the existing outlet, you can purchase a new outlet, that matches your plug, and replace it. Verify the voltage and amperage required by reading the label that is on the back of the dryer or in the owners manual to be sure you get the right one. You will also need to verify the wiring and breaker at the main panel. Be sure that the wires go to a two-pole breaker that is rated for 20 Amps (or whatever the dryer is rated for) and not two individual breakers. If the dryer is rated 20 amps make sure you have a minimum of #12 gauge wire, if the dryer is rated 30 Amps, the wire needs to be #10 gauge.
Posted on Sep 12, 2009
Is their any way to ground a three prong house plug-in from a two wire
replace the outlets to 3 prong IF there is 3 wires in wall if not you cant do anything except replace wire
Jan 16, 2012 | Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I have a whirlpool eltri dryer model #Lhe5700w0 it as a 4 prong recptacle and my otlet hasonly three slots
you have two options you can either replace the outlet on the wall to a 4 prong plug which will require turning power off and a little more description on how to change ... you have 2 hot legs usually black and red sometimes they will use black and the white and then connect the ground to the ground terminal... you would install the 4 prong outlet the same way except you would conect the ground to the center port and then ground the receptacle itself...
the easiest thing to do is go to a local hardware store and buy a three prong cord and in the rear of your dryer is a access panel to replace the cord... the 2 outer screws are your hot legs if you hold the cord flat you will see it is made where you can tell which wire is what, doesnt matter which is which as long as the 2 outer one are the two outer ones on the cord and the center wire goes to the center screw and then all you have to do is plug it in and start drying clothes.... good luck to you
Feb 18, 2011 | Whirlpool Dryers
Can i switch the plug on my dryer
If you change the plug on your dryer to a three prong and plug it in that way it will work, however it will not be up to the latest electrical codes where the dryer needs to have its own ground, not share that ground with a neutral. I would recommend running a new wire 10/3 with ground with a new four prong outlet (note: if you already have the 10/3 wire there you can just as easily change the outlet; red and black are hot wires, white is your neutral, and the bare copper is your separated ground) . However if you would like to just change the plug to a three prong you have to make sure your ground bar is tied to your neutral bar and there you only have three wires, 2 hot and one neutral.
May 03, 2010 | GE DBXR463EBWW Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Electric Dryer
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
Jun 09, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
