Yup ... two items...
The fuse is in the fuse box along with all the other fuses for your radio, heater, etc.
There is also a safety cut-off switch inside the Jimmy behind the panel near the gasoline filler tube.
Hope thsi helps!
Check fuel pump relay in engine compartment look under fuse cover to identify which one then make sure all electrical connections are making good contact, slightly bend tabs and clean
The fuel pump has a fuse, it is located in the under hood power distribution box, it just beside the fuel pump relay, believe it is marked ECM 1.
