Question about Wader Classic Basic Wrecking Tow Truck by
Have 98 International D4700 tow truck. Was hooking up longer line for tow lights, think I blew a breaker. Have turn lights but no brake lights. Where are the breakers located?
    Problem Solver:
  • 14 Answers
Does this tow truck have the DT466 or T444 so we can narrow down which diagram to direct from?
Posted on Sep 17, 2009
HOW TO TOW MY 4X4 JEEP WITH MY PICK-UP TRUCK? WHAT TO DO WITH GEARS?
Hello! Please tow with the front of Jeep at the Pick-up bumper (reverse) Your odometer will not turn (no miles registered for the tow) also, the brake lights should be wired together so you have brake lights on the towed vehicle.Or buy the kit. Put the Jeep in neutral. Chain the front suspension of Jeep so you only have 15-20 degrees movement. Chain the cars together with two different sets of chains- one to the tow hook and one frame to frame. Put a sign and red rag on rear of Jeep.This is a safe tow.
Aug 15, 2011 | 2000 Jeep Grand Cherokee
Brake light on
check your lines, mine was on for 2 weeks, and my and my rear driver line blew. Remember you only have one reservoir. so if it happens, you'll need a tow, or drive home with little brakes.
Jul 11, 2011 | 1997 Dodge Caravan
1995 jeep cherokee 4wheel drive my right back has brake fluid spilling all out it all over rim i just had it towed AA the guy towed it 1 block and then called for a flat bed truck do you think something...
I would say if it did not leak before the tow that they definitely did something to it during the tow. They probably hooked a hook around the rear end and tore the brake line. If you have any more questions about this feel free to ask and I will do my best to answer them.
Jan 31, 2011 | 1995 Jeep Grand Cherokee
2004 x-type jaguar stuck in park after tail light problem . Simple brake light replacement turned into a nightmare. Scared to have the car towed.Can,t afford to have a jaguar tech come out, We're screwed....
Check the brake light fuse. If you blew a fuse for a brake light, you won't have power to the shift interlock which allows you to move the shifter.
May 19, 2010 | 2004 Jaguar X-Type
Brake Box Will Not Work
First try a 12 volt "stab in" test light pushed into the blue wire at the brake controller. Red is brake feed from the truck, black is 12 volt power and white is ground. If all is wired correctly, the blue wire should power up when you hit the brakes. Be sure to turn the controller up to highest setting to test it. When you hook the test light up, the connection indication light should come on. Then turn red when you hit the brakes. Also see http://www.etrailer.com/faq-wiring.aspx for more info.
Oct 22, 2009 | Pioneer Voyager 4000 HD-DVR
Braking lights and turn signals not working
Did you check the brake and signal light bulbs? If something happened that blew a fuse, chances are you probably lost some bulbs too. that should fix your problem
Oct 20, 2009 | 1999 GMC Yukon
98 mazda b2500-my turning signal/hazard lights no longer work
You need to replace the flasher module, this is the module that controls the "Blinking" function of the lights, its a mostly a common part that you can get at any auto parts store for less than 10 bucks and is located in the Fuse panel under the dash, its round in shape in one corner of the panel. mostly they are green in color.
Oct 02, 2009 | 1998 Mazda Pickup
Trailer fuse blows when hooked up
Is your truck wired for a 7 pin flat plug? if so are you using an adapter? The adapters are made differently. One has the center pin as brakes and the other uses the center as Aux. power. Any chance of an animal getting to the wires? They are kown to chew on the wiring. Also try http://www.etrailer.com/faq-wiring.aspx. They have a great website with lots of info.
Jun 02, 2009 | 1999 Dodge Ram
Tow plug
I take it the blinkers and brake lights work ok when not hooked up to the trailer? If yes, then the wiring to the tow hitch is not hooked up correctly. How many wires to trailer pig tail connection? U can have up to 7 depending on what you tow. Check to make sure these wires are hooked up from the truck to tow plug correctly: 7 wired---
brown-Rt turn and brake light, yellow-backup, white-ground, blue-electric brake, green-tail running lights, black-battery charger, red-left turn signal and brake light. Let me know if u have something other than 7 wire, I'll get the wiring color and source info for u.
Nov 25, 2008 | 1998 Ford F150 Regular Cab
Wader Classic Basic Wrecking Tow Truck by Logo
133 people viewed this question
Top Wader Toys Experts
ray gallant
Are you a Wader Toy Expert? Answer questions, earn points and help others
