Question about Dryers
Hotpoint condenser dryer stopped working. First it stopped after 10-20 minutes, so I thought it overheated so i hoovered out all of the fluff from the door and side panels. Then switched it on and it was still the same so waited for it to cool down a little and turned it back on at low temp and now it wont start. mains fuse hasnt blown as led's on the front still come on.
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Beko DRCT 70w condenser dryer not heating inside drum element is new and works any ideas ?
check the 2 thermostats with the element.........if ok.....
check the condenser unit.......they fill with fluff and stop condensing.......i use a hose pipe to shift all the fluff.....
cheers
Nov 23, 2016 | Dryers
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
My hotpoint condensed dryer is steaming up my windows and I don't know why as I thought that was the point of the condenser. It's model number is Tcm 850, anyone got any suggestions or can help, thanx
Hello Scot, just make sure the fluff filter is clean and the exit tube for the air is clean they should just slide out fluff filter and pull off the fluff and the air exit tube normally get quite dirty with fluff and debris. So take that out and take it outside and wash it through with a hose from both ends. The water tray should also be emptied regularly but the panel will tell you when that is full.
Hope that helps
Steve
Oct 12, 2013 | Hotpoint Dryers
Wd440 not drying. how does the fluff get emptied?
Because it is a washer dryer, there is no fluff filter to clean.
It is self cleaning, because the fluff is washed away by cold water entering the condenser and flushing the fluff away.
Trust this answers your query.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Washing Machines
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
HOTPOINT CTD40 CONDENSING DRYER not drying clothes any more.fault codes is on/off light and time delay lights are flashing after 30 seconds of switching the appliance on.the condenser unit is free of fluff...
Without actually taking meter readings I would suggest that its probably the thermostats that are fitted to the heater unit on the back of the appliance.
Hotpoint Part Number: 1703607
Hope this helps
Aardvark repairs
Nov 16, 2009 | Hotpoint Dryers
How do i clean the condenser on my hotpoint tdc32?
Remove condenser, and flush it out under a running tap, or hose pipe with cold water, this will flush all the fluff out of the condenser
Thanks.
Aug 07, 2009 | Hotpoint TDC32 Electric Dryer
Fluff removal
you will have to manually  Remove condenser unit and clean any build up of fluff from between the arears of the gaskets and the inlet covers.
Feb 20, 2009 | Hoover HW160M Front Load Washer / Dryer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Jan 19, 2008 | Dryers
Dryers Logo
125 people viewed this question
Top Dryers Experts
