Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Forgot to put oil in the gas for my trimmer and blower. will not start now. can this be fixed? how?
Pour out all the gas and make up new batch you may have to replace the plug but otherwise your still in good shape
Posted on Sep 12, 2009
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
What is the fuel mix required?
Pirelli an amazing walk on Christ The Redeemer
HB 180v home light mix at 32 to1
read it on the oil can, bottle, put 1 gal gas in first a marked clean gas can, and ad oil last watch the gas pump not the can, and stop at what amount of gas you need get 100 percent gas in all your trimmers ,blowers! // if the can you are going to use only has a small amount pour it out it might have water in it and that's another story. Rideau Canal Oil Gas Fuel Mix Tables and watch this neat video Christ The Redeemer!
Aug 21, 2014 | Garden
Problem with Lawn Trimmers & Edgers I put a
Yes, this should not hurt it, just clean the plug and crank until it fires up, it will smoke until the oil has gone. Are you sure it is a four stroke machine?? as most are two strokes and do require a fuel/oil mix.
May 14, 2013 | Garden
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My 2 cycle gas trimmer will not start? It's only 2 years old
Have you cleaned the spark plug , replaced it, or the carberation system?
If not, then this could be the problem.
Plug builds up corrosion over a period of time and cleaning is requird. also resetting the gap.
GAs goes stale too to flush out the old gas and put new gas.
Jul 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I just foun out that i forgot to add oil to gas mixture to my blo
hello, what you should do is drain out the gas from the tank into a clean container so you can add the oil to it and you should also check your spark plug make sure it's o.k. after draining out the gas try starting the blower a few times with out the spark plug wire connected to the spark plug this will flush out and of the pure gas from the fuel lines, after doing this re-connect the Spark plug wire and add your fuel/oil mixture and re-start, it might take a few times for it to start due to all the gas in the engine but it'll start also if your blower has a primer bulb you may want to prime it a few times after adding the fuel oil mixture to get it in the combustion chamber, if after doing this you still get nothing you'll want to re-place your spark plug it might be fouled out. good luck
Mar 25, 2009 | Craftsman 4 Cycle Blower/Vac
Leave blower and vac
I don't mean to over simplify this, but are you using fresh gas? Gas blowers and string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. Not just fresh from the can, but fresh from the pump! And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers and blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 04, 2008 | Craftsman 4 Cycle Blower/Vac
Staring difficulties
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 02, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
133 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
