Question about KitchenAid KHWS01PWH Global Horizontal Axis Washer
My Kitchen Aid Washer model#KAWE577BWH1 runs through the cycle but does not spin. I opened it up and the drive coupler is fine. What should I do next?
  • 6,784 Answers
HI. the first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission
. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
***(I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,motor board,transmission))). inspect these areas thoroughly)
Ok, if all the above checks out ok and, there are no signs of damage to any of the above parts stated, this will confirm a timer control module malfunction. replace the control device(timer or control board) asap, if possible.
Posted on Sep 12, 2009
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Will not agitate or spin
On Whirlpool brand made machines the drive coupler between the motor and the transmission is probably stripped out or broken and needs to be replaced.
Keep in mind that Whirlpool also manufactures: Estate, Roper, Kitchen Aid, some Kirkland and some Kenmore washers. All have the same coupler that gets stressed and breaks. A cause for this often times is overloading the machine.
After inspecting and finding the problem, make sure you have the model number and call your local appliance parts store or repair center and they probably have your part in stock.
Repairing a stripped out coupler is pretty easy for the doit yourselfer.
I suggest watching this video before attempting the repair:
http://www.youtube.com/watch?v=WLPGs2UMUJc
Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
My question is: When I first got my washer it
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Jan 05, 2010 | Samsung WF337AA Front Load Washer
I have an old model 110.82074110 that is slow int he spin cycle. I believe it is slipping in the basket drive. Is there a way to adjust? Thanks in Advance Larry
Jan 02, 2010 | Washing Machines
I have a KAWE577BWH1 washer, it is not spinning during the spin cycle and is making a clicking sound
What you have is probably a broken drive coupling. These machines are designed to be repaired in place. A tech flips up the contrls and unplugs the lid switch harness. The tech then pops the S clips and removes the case. This makes it easy to access the motor,pump and that old broken coupler. Take a look at these repair pix
Aug 20, 2009 | Washing Machines
Washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Aug 11, 2009 | Kenmore 43042 Front Load Washer
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
276 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
