Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water level when you turn on the water level of washer goes to the top it will not change the level like low or medium[all i did was change the water pump
  • 105 Answers
Either the water valve is not working
not working meaning that has crap under valve seat and letting water flow all the time
or pressure switdh is not working
try taking hose off at the p/s and blow back into bowl then try again
Posted on Jan 05, 2008
Hello--My Maytag washer LAT8614AAE stopped while filling. It still spins, and stops spinning when top opened. I replaced water valve, so that wasn't the problem. Ideas? Thanks!
I would check the water level switch. It is activated when the water level is as per requested (low, medium, full). It might give the OK to the timer.
Jan 23, 2018 | Maytag Washing Machines
WHY IS WATER LEVEL LOW CAN I CHANGE THE SETTING ON WATER
there should be a knob on the control panel showing small, medium, large maybe even super. that is how you change the water level. Its for different amounts of clothing your washing at a time. If you put in a few clothes then you have the option of using less water.
Jul 31, 2014 | GE WBSR3140DW Top Load Washer
Low oil gage and wont start1998 mercury mountaneer
check engine oil level sound like oil level very low.if oil level okay problem could be faulty oil pump or oil pump shaft to distributor broken or timing chain has lot of slack causing oil pump not to turn fast enough build up oil pressure or engine bearings worn out.
Feb 07, 2013 | 1998 Mercury Mountaineer
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
The water level never stops, it just fills till it over flows
if on auto level select water level eg medium or low depending on amount of clothes this sometimes works dont use auto water level. If not check small pipe under touch board on top panel, make sure u unplug mains from plug pipe may be loose its small plastic goes to level sensor on right of board. If not level sensor faulty.
Feb 21, 2011 | Haier HLP21E Top Load Washer
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Washer will not fill before agitation
The settings on water level may be set on very low amount. Check see your water level is set on medium or full. You may be expecting the wrong amount on the low setting.
Feb 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
26 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
