Question about Hifonics TXi4408 Car Amp
I accidently shorted a speaker output to the frame with it on. Since this happened, I have a whine that is constant and increases with engine rev. The rca's are isolated from voltage, and the system sounded fine before this happened.
  • 52 Answers
Sounds like a one of your capacitors in the output stage of the amp, might have been damaged. You could also try a resonator on the 12 volt supply coming from the battery.
Posted on Sep 12, 2009
Is the servo u's if the engine revs increase when braking?
Hi Gordon:
Don't know about servo's but here are two circumstances that I know can be real:
1) gas pedal and brake pedal may share a common linkage component. When the brake pedal is depressed, "drag" on the throttle component could occur, opening the throttle..
2) Brake pedal and gas pedal may be close enough that the sole of your boot can "overlap" and catch the cas pedal at the same time that you are pressing down on the brake. This has happened to me, and has been the documented cause of accidents.
Hope this is of some help.
Cheers.
Nov 26, 2015 | Cars & Trucks
The amp gets power, however the speaker emits a constant whining sound
Sounds like the output capacitors are breaking down, or you have a faulty pickup causing feedback, this can also be caused by bad cables close to ac power causes hum and distortion.
Jun 18, 2015 | AMP Music
High intermitent revs at idol and while driving
If engine is increasing/decreasing constantly this is called hunting. Or does it suddenly just rev wildly then go back to normal?Please give more detail and resubmit. Please andd make model year and engine option of vehicle
Jun 02, 2015 | Cars & Trucks
How to troubleshoot a high pitched whine in the right fron side of my Nissan Maxima 2004
Could be one of the belts slipping or worn out. Might even be the water pump bearing. Does the whine increase/decrease as you rev? Whine louder if you suddenly accelerate?
Dec 09, 2014 | 2004 Nissan Maxima
Power Steering Pump Whining?
Yes I think it would. It is probably the shaft bering faililng.
Jan 22, 2014 | SK Hand Tool Altenator / Power Steer /...
Whine in engine-connected with acceleration
It could be the belt, but the belt is not an easy thing to change for a "mechanically illiterate" person. Also possible is that the "whine" is coming from one of the many components that it drives. In either case, the belt will have to be removed (and maybe even replaced due to it's age). The mechanic removing the belt can better carify the source of the "whine". As info, I repalced my belt at about 60K miles - but, it had a high frequency "ticking" which also increased in frequency with engine speed.
Nov 28, 2009 | 2005 Chrysler Town & Country
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
New amp is whining
Try switching power amp output's to the speaker's and see if it still does it if it still does it the it's the speaker ,disconnect every thing from the input's of the power amp if it stop's start pluging thing's in one at a time ,process of elimination best of luck
Dec 27, 2008 | Audio Players & Recorders
Engine whine
You're hearing whine from the alternator as it charges the battery. You could reduce it by turning the input level down on the amp, or by adjusting the filter on the high end. You can also buy a whine filter kit.
One last thing... you may have blown one of the diodes in the Alternator itself when you shorted the speaker wire. It would still work and charge the battery, but would not be able to filter the whine like it should.
Hope that helps...
Geno
Mar 25, 2008 | Eclipse XA5000 Car Audio Amplifier
Hifonics TXi4408 Car Amp Logo
23 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
