Question about Microsoft Xbox 360 Console
It will come on but cant see see the green cant the the game disp
The game that I put in the display will come on but it wont allow me to go to the game or set up or do any thing other than see the display it will come on but cant see see the green cant turn controllers on to it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
Make sure this is a xbox 360 game, if it is an xbox game not all of them work on the 360. you can check the list of compatible games on the web site, there are updates you can get for some of them. If this is not the case and the game is for xbox 360 and your other games are working fine, I would suggest that the disk is bad, if you can, try it in a friends machine and see what happens. I hope this helps. Good luck.
Posted on Sep 13, 2009
Low tire pressure light wont go out
The Low Tire Pressure Indicator must be reset using the Radio. This can only be performed if you have the factory radio installed in the vehicle. This vehicle does not come with an active tire pressure management system, and as such, this light must be reset manually.
1.) Turn Radio Off 2.) Hold down disp button for 10 seconds 3.) Setup Menu should display 4.) Scroll through menu to view "Tire Pressure" (use seek buttons) 5.) Select the Tire Pressure option (Press Radio Button 1) 6.) Reset should be displayed on screen (Press disp button) 7.) Tire Pressure Light should reset
Nov 29, 2010 | 2000 Chevrolet Impala
How do i program a keyless entry for a monta carlo 01
1. Turn the ignition to ACC or ON and the radio to off. Do not crank the engine.
2. Press and hold the DISP button on the radio for at least five seconds until settings is displayed.
3. Press the SEEK up or down arrows until FOB PROG appears on the display.
4.
Press the PREV or NEXT button to enter the submenu. The current selection will have an
asterisk next to it. BEGIN will be displayed.
5.
Press the DISP button to start programming. When the message PUSH FOB flashes, press and
hold the LOCK and UNLOCK buttons on the first transmitter at the same time for 15 seconds. A
chime will be heard to verify the transmitter is learned.
6. Repeat Step 5 for each additional transmitter up to four remotes total. You do not need to press
the DISP button again, just press down the LOCK and UNLOCK buttons on the next transmitter
to be learned to a maximum of four transmitters per vehicle.
The mode you selected is now set. You can either exit the programming mode by following the instructions later in this section or program the next feature available on your vehicle.
EXIT (Exit Feature Customization Mode): This feature allows you to exit the vehicle customization programming.
To Exit:
1. Scroll until EXIT appears on the display.
2. Press the DISP button to exit programming. A chime will he heard to verify the exit.
Jul 10, 2010 | 2001 Chevrolet Monte Carlo
I CANT VIEW IN THE VIEWER WHEN IN THE CAMERA MODE. IT WORKS FINE IN THE VIDEO MODE.IT WILL TAKE PICS IN THE CAM MODE BUT NO SCREEN.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 23, 2010 | Canon PowerShot SD600 Digital Camera
I CANT GET THE DATE TO DISPLAY ON STYLUS 7010
there is a display button at the bottom right of the back of the camera. its the very bottom rocker buttons. it says DISP/? or/(and the trash symbol). knowing this go to look at your pictures (using the "play" symbol) and click DISP. the time and date should appear now.
Mar 21, 2010 | Olympus Stylus 7010 Digital Camera
Ps3 only works on my HD tv.
when you turn on the ps3 from the switch on the back, when the light turns red, hold down the power button on the front instead of tapping it to turn the light green. Hold it for atleast 5 secs. This restores the display settings.
Feb 20, 2010 | Sony Video Game Consoles & Games
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
PS3 WONT LOAD OR READ DISCS. FROZE ON MAIN MENU GAME DISPLAY.
Check out my blog for help fixing the problem.
Start with # 3 on my 5 Most Common Errors entry.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
How do you set the clock on the panasonic cq-c1121u cd radio.
1 Turn the ignition switch until
the accessory indicator
lights.
2 Press [SRC] (PWR: Power).
3 Press [DISP] (CLOCK).
4 Hold down [DISP] (CLOCK) for more than
2 seconds.
5 Adjust the hour.
[[]: sets the hour ahead.
[]]: sets the hour back.
6 Press [DISP] (CLOCK).
7 Adjust the minute.
[[]: sets the minute ahead.
[]]: sets the minute back.
8 Press [DISP] (CLOCK).
Notes:
¡ "AdJ" is displayed before adjusting the clock.
¡ Hold down []] or [[] to change numbers rapidly.
power off displayPower Off
Press [DISP] (Display) to change the display.
Mar 10, 2008 | Audio Players & Recorders
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
