TV Display doesn't work
I have a Toshiba Trinitron CRT TV. The screen doesn't always work when I turn on the tv, but the sound always does. I saw a similar problem at
http://www.fixya.com/support/t277853-picture_wont_turn
and someone suggested that some resistors had "gone high." Can someone explain that lingo to me? Does it mean that I find a resistor with a different ohm measurement than specified by the color bands that I should replace it? Will that solve the problem?
Thanks!
  • 556 Answers
SOURCE: resistor
http://www.eserviceinfo.com/downloadsm/25749/RCA_24F512T.html
down load the schematic diagram &get the value.
hope this will help you.
Posted on Oct 12, 2007
  • 20 Answers
SOURCE: Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen
Check vertical i.c.
Posted on Mar 17, 2008
  • 280 Answers
SOURCE: Partial horizontal collapse. Nu-tec Model NTT-829A
If you have retrace lines I would recheck all caps around the vertical IC 100@16 is the most common 47@35 and 220@35
Posted on May 30, 2008
SOURCE: Sony KV-35S42 35" keep blowing MX0841 and .1 fuse resistor
Normalmente cuando falla la fuente se dañan los transistores convertidores, la resistencia 607 de 0.1 ohmios los condensadores C609, C610 de 0.47 mf. C611, C612 de 0.22 mf.
En nuestro caso basto con cambiar el MX0841 y R607, ya que el daño se debió a una sobrecorriente provocada por la salida horizontal, esta fuente e mas robusta que la de otros modelos ya que accidentalmente se provoco un corto en la salida del B+134 y simplemente solo se daño el MX0841 y la resistencia R607, se cambiaron y la fuente volvió a funcionar perfecto
Posted on Dec 04, 2008
daniel719
  • 240 Answers
SOURCE: Sony TV KV-32v15 Dead Power Supply
you should of recived a 0.01ohm resistor it is wite and sayes sony on it.
its a flame proof resistor that needs to be the very same
look for it on the pcb test it its probly open right.
ask them to send you the right part.
regards,
daniel.
Posted on Jan 11, 2009
15 yr old sony trinitron tv
It sounds that the video output section circuit bard to this TV have some loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. The video output section board can be located at the neck of the picture tube, will directly plugged on to it. Check it. If you wish to know more details about single color display screens, check this site. It has details to that problem. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Toshiba CF27H50 TV
Sony trinitron kv28ws2u turns on but has no display sound can still be heard through the stereo
If you have a DVD player etc hooked to one of the rear inputs see if it works---if it does suspect signal source is down (ie if using a box of some sort unplug it and plug it back to let it reboot.)
May 01, 2012 | Televison & Video
The on screen display doesn't go off how do I fix this?
if you are not a tech then dont repair.have a tech repair your tv.the eeprom IC in your tv is faulty.it wants to be replaced.good luck.
Sep 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Chanel numbers and video stay on screen. example the number 3 always on in corner of TV screen or video number always on the screen.
hello, you should press the display button
at the remote control that marked with the i letter or with the ? sign . good luck!
Feb 09, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Cable tv issue
first ,replace the tv-dvd cable,then ask me again.
May 04, 2008 | Toshiba 36A40 36" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
