Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
I have a Panasonic PT-53TW53G that stopped working. Red LED light blinks 3 times. Any advice?
  • Panasonic Master
  • 8,617 Answers
The 3 blink error means the convergence has failed and has shut the set down. You can get the convergence repair kit for your model at the following link www.tvrepairworld.com The kit contains the parts and the Cd with detailed instructions
Posted on Sep 13, 2009
Testimonial: "Thanks - I went to their site and the only model that comes close to mine is PT-53WX53G - mine is PT-53TW53G. I contacted them waiting to hear back."
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV not turning on..blinking red on power
the blinking pwer indicator is an error code. How many times does it blink?
May 13, 2009 | Televison & Video
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
324 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
