Question about Garden
Pressure washer will not sphion water from the detergent bottle
    President:
  • 1,462 Answers
These are various reason for your issue and various solution for your issues,
1)
Brass knob on injector is closed.-Open by turning counter clockwise
2)
Unit not in low pressure mode.-
Open by turning counter clockwise.
3)Detergent hose cut or kinked.-Inspect hose, replace as required.
4)Strainer plugged or not submerged.-
Check screen on strainer pickup tube.
5)Internal injector parts corroded or stuck.-
Disassemble, clean or replace.
6)Outlet water temperature too high.-
Use with cold water (150º Maximum)
Enjoy! Rate this solution
RNJ VINOD KUMAR
Posted on Sep 12, 2009
I get no water pressure when I connect detergent bottle. Why?
Many pressure washers only use detergent with the low pressure head. Check the manual for your model.
Jun 24, 2016 | Garden
How is detergent bottle connected
on others that I've used I just stuck the clear plastic tube into the bottle and set the bottle on the ground
Mar 07, 2015 | Psi Garden
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
How to repair non-functioning detergent bottle
Are you really sure it's not working? Most of these only dispense detergent when the lowest pressure spray head is attached. If that's not the problem then the next most likely thing to check for is a blockage in the tubing that connects your detergent bottle to the main unit. If this was not fully rinsed out after the last time it was used, any residual detergent remaining in the line will often solidify which results in blocking the line. Good luck
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
It is only one year old and only been used last summer when i got it out this spring the detergent will not dispense
take off clear tube that goes into solution jug(where soap goes),make sure it is clear(water passes thru it easily) use a soda bottle- fill with vinegar- reattach hose and put other end in soda bottle- if this doesn't work that valve in the sprayer itself is gummed up- sometimes using HOT water feed sprayer will clear an internal plug
May 10, 2011 | Briggs & Stratton Prosumer 20324 Gas...
No pressure with detergent bottle on
you wont get pressure with detergent bottle on.it only sprays low pressure .just take off first section of wand,and plug it in
Jul 05, 2010 | McCulloch FH140A Electric Pressure Washer
I have a detergent tank and cant seem to get detergent to come out what do I need to do?
Dear bug4222,
I have never worked on your type of machine. But generally this is what you do. Disconect the pipe from the inlet to the machine. Attach another pipe and put the other end in a bottle of water. Start machine and on low pressure see if the machine sucks water from the bottle. If this does not happen, try to service the inlet part at the machine. This usually it will have a ball-bearing as a non-return valve. This non-return valve sometimes gets stuck. If you see that you have solved the fault in the non-return valve, attach the detergent tank as it was, but instead of detergent, use water. You should always use low pressure. If all is OK, try some detergent. Always remember that after using detergent, always pass clear water from the detergent tank. If you leave detergent in the system, this will cause problems.
Regards,
Fultech.
Jul 16, 2009 | Campbell Hausfeld Garden
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
