Question about Denon AVR-95 Receiver
Standby flashing avr has been my control4 whole house for awhile. just went out. if i power on, the screen begins to show everything firing up, but then the screen goes blank and the standby just flashes. the manual says that it is overheating? i had it unplugged and off overnight with the same results this morning. tried power on while holding direct and stereo buttons but that also did not work.
  • 382 Answers
Thats the protection circuit kicking in, overheating is rarely the problem, check your speaker wires for shorts. If it does that with nothing connected you have a bad amp board :(
Cheers,
Posted on Jan 07, 2010
I have a Denon avr 2801. My standby light is flashing and i cant seem to reset it. I have tried pressing the a and b buttons together and then turning the power on, all the lights flash but thats it.
Hello
There is always a constant 5v for the device to go to standby.and power on when you press the power button .
This flashing is not to reset the device it shows that there is a problem with power supply.
the regulators are burned or over voltage ...
it needs service .
hope this helps
good luck
Jan 20, 2016 | Denon Audio Players & Recorders
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
Control 4 system
I think you double posted, so I will just mimic my other answer
If i understand you right, you are playing your CD from your computer. If this is correct, you should burn your cd's into MP3 format with windows media center. Then let you Control 4 system get your music through your network.(you will need to call your Control4 dealer to setup this.) You should use a network hard drive to save you music to. but it can be done with only your computer. If you use your computer you need to make sure that your computer stays on, so turn off the screen saver and your power standby and hibernate options.
I hope this helps. If you live in Utah, I work for a control 4 dealer in Draper. If you have any more questions, e-mail me at joe.4home@gmail.com you could also visit a end user control4 site at http://www.c4forums.com/
Joe
Dec 14, 2008 | DameWare Mini Remote Control 4.x (dmrcupg)...
I have a Control 4 system. While playing CD's, the TV screen flashes "no signal" and the music will eventually stop. I was told to press the "fn" and "f4" key on the computer to switch itover, but it isn't...
Joe
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Denon AVR-1508 Standby Issue
The problem is with one of the Channel power transistors. I have the same problem I am searching to find out how to test them to find out wich one is bad.
May 14, 2008 | Audio Players & Recorders
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
166 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
