Question about HP Photosmart 8250 InkJet Printer
Error0xc18a020a I have just opened packages and put cartridges in the printer - whether or not they have expired - they are full of ink. I shook them and ink drops came out of one of them so looks like the ink should flow. I just want to print a picture! I have had trouble with this before and have given up. Then the ink cartridges get old. However, if there is ink in them - the printer should print. I would like to solve the problem this time around.
    Problem Solver:
  • 6 Answers
So the error message that you have got on the screen that says 0xc18a020a is the error messgae when ur cartridges are not getting detected by the printer so in this cases we have to service the printer only
as u may try these steps like cleaning the copper contacts of the cartridges and then aligning them but that is also not going to work
so u must go ahead and try service ur printer ..........
Posted on Sep 20, 2009
  • monicasity Jan 01, 2011
    Why would we have to have the printer serviced. I'm tech savvy and can understand the reason...certain things I would still trust a professional to do but I wan't to know what it is first.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
Jul 06, 2014 | HP DesignJet Office Equipment & Supplies
Yellow ink will not show on test page. It is full. New
Open it up and look at the yellow ink cartridge. Make sure all of the packaging is taken off, since it is new. Put it back in and give it a shot. Sometimes just reseating the cartridge can help.
Mar 05, 2011 | Epson WorkForce 600 All-In-One InkJet...
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
My hp officejet 4315 all in one says Cartridge error.. I replaced the cartridge one week ago it is still full of ink I took it out and shook it.. And put it back in. I unplugged the machine and still...
I replaced both cartriges bought at cartrige world. Screen on printer says: "Cartridge Error". I reinstalled both cartridges and still get "cartridge error". I don't have a owners manual, Help!
Roger
Jul 11, 2010 | HP Officejet 4315 All-in-One Printer
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Sep 12, 2008 | HP - HP Photosmart 8250 printer
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Magenta cartridge
I just wrote the same solution but I'm not familiar with this site however, I am JonathanD. I read about the ink cartridges having an expiration date on a chip that prevents the printer from recognizing the ink cartridge after that date. I called Canon to find out where that date is located on the ink cartridge or packaging so I can see how long it's good for when I buy them. They told me that there was no expiration date and the ink is good indefinitely... so I told them what I heard about the chip. I was then put on hold for a while and when they got back on the phone, I was told that they were sending me a new Magenta 8 cartridge "as a courtesy."
Dec 17, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
HP Photosmart 8250 InkJet Printer Logo
616 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
