Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
Windows vista closes my program
By Luis_hdz411 on Dec 11, 2007
I have a program called Magix Audio Studio Deluxe7. I have used this program for years.I downloaded it to my laptop,it worked fine. One day i had a usb scandisk connected to my p.c., then my p.c. went to sleep and when i tryed running it again it froze due to the scandisk. Every since that day whenever i try to open Magix Studio i get------------> A problem caused the program to stop working correctly.Windows will close the program and notify you if a solution is available.......Which of course they dont send a solution.I have un-installed and re-installed the program and it still doesnt work.Please help me with this program.
Comments:
Dec 11, 2007
- I've done all of the things you posted and it didnt work. :(
Keep it coming if you have any other ideas.. Thanks for the help.
Dec 11, 2007
- i un-installed and re-installed but now i cant un-install again. NTVDM.EXE is not responding. Thats what is coming up. Now I need a resolution for this problem as well.
Dec 12, 2007
- Ive done all these things before following the help and support tips. I have also recovered my p.c. once and when i in-stalled the program again,..the same message came up. I was gonna recover it one more time and see what happens but hopefully something comes. Pleez keep the good stuff coming. It is most appreciated.
Solution #1
posted on Dec 11, 2007
Somewhat Helpful)
country42740
Rank: Wiz
Rating: 80%, 452 votes
Why is Windows closing my program? Applies to all editions of Windows Vista.
Which edition of Windows Vista am I using? Windows might close a program and then notify you if it determines that the program is either a security risk or incompatible with this version of Windows.
When Windows closes a program because of a security risk, it is because some programs might use your computer's random access memory (RAM) in a way that could be exploited by a virus and harm your computer. Data Execution Prevention (DEP), a security feature of Windows, tracks how programs use memory. If DEP finds memory being used incorrectly, DEP will close the program and let you know. If you trust the program, you can add it to an exceptions list so that DEP won't close it, but you should first check with the manufacturer of the program to see if there is an updated, DEP-compatible version available.
When Windows closes a program because of compatibility issues, it is because some programs could damage Windows if you try to run them. If Windows notices that an incompatible program might harm your computer (for example, by damaging important system files), Windows will close the program and notify you. Check with the manufacturer of the program to see if an update is available, or check Problem Reports and Solutions in Control Panel to see if a fix from Microsoft is available.
• Open Problem Reports and Solutions by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Problem Reports and Solutions.
If this dont fix the problem......... id re-store the computer with the restore cd that came with your computer. Good Luck hope this gets your computer back up and going.Please dont for get to Vote. Thank You.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
CoDoc
Rank: Master
Rating: 93%, 21 votes
Hi Luis, Have you tried running the program as administrator? or under compatibility mode? If you have already, the problem may lie in a corrupted registry, try un-installing MASD7, running cCleaner , the program deletes all unnessacy files from your computer, then try its registry tool. Run that two or three times till no errors show up, and install MASD7 and run under vistas compatibility mode, Good Luck
CoDoc
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
When turning on my computer goes into automatic power save, monitor screen does not turn on.
Answer
When I open Word, the cursor doesn't do anything. I can't open a document or anything else.
Answer
How to send emails on windows office 2007 and how to send emails on office word 2007
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating Systems Experts
Top Computer & Laptop Repairmen
in , AR
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
