Question about Toshiba 42H81 42" Rear Projection Television
Green the picture looks good but turns green
  • proskill Aug 10, 2008
    my screen is green most of time then gets better than goe green
    Problem Solver:
  • 17 Answers
Take the tub off of the back and there will be a red, blue , and green turn dials that adjust th focus and adjust the color apptitude adjust it accordingly
Posted on Dec 11, 2007
The picture turns green for a few seconds then goes back to normal
Hi. If it's not a picturetube (internal) fault, you may look for bad soldering joints on the printed circuit board, located at the tube.
This contains mostly the RGB amplifiers. A bad soldering on the one driving the "green" cathode, may cause such problems. It can easily be detected by gently knocking on the latter. Also look at the actual CRT socket solderings.
It is most unlikely that the fault is located in the colour decoder. Faults there mostly influence red and blue. In a PAL system, only red and blue are transmitted. Green is produced by a matrix.
Finally, in the worst case there is an internal fault in the picture tube itself. Usually, the discolouring is very bright, shows retrace lines across, and even makes the system shut down due to excessive beam-current. good luck.
Apr 13, 2014 | ESA ET427E 27" TV
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
Apr 24, 2006 | Toshiba 32A60 32" TV
Toshiba 42H81 42" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
