Question about LG enV VX9900 Cellular Phone
The keys on the upper part of my front screen keypad for my envy 2 quit working. What can I do?
My precor ex 5.24 is showing an error 05 on the screen. What does that mean and how to solve it?
please proceed according and fix it. God bless you
Description
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Jan 08, 2013 | Exercise & Fitness
Treadmill not working at all
follow the steps and fix it. God bless you
Possible Causes
Possible Remedies
upper PCA.
Nov 15, 2012 | Exercise & Fitness
546i stuck key elevation does not work
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Jun 02, 2011 | Precor EFX 546i Elliptical Version 4
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
I am getting a reading on the screen of "er 05" i
Corrective Action
Mar 21, 2011 | Precor 9.31 Treadmill
All buttons have stopped working
Hi, different possible places to check,
The flex,
keypad IC.
The flex of the phone.
The flex is connected to the screen and it makes the screen display,Also if the flex gets damaged it will make the key pad not to work.
The keypad IC is found inside the phone boardand it make the keypad the function.If IC gets damaged, might cause keypad noe to function.
It depend of the keypad your talking about, if it's the lower key pad or the upper keypad where the menu is.
If it's the upper keypad is damaged, that means the keypad area is faulty,and will need to be replaced.
Have a nice day.
Sep 03, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Screen is flashing key depressed and won't work. How can i fix the machine?
Corrective Action
Aug 18, 2010 | Precor EFX 546i Elliptical Version 4
The red key to switch on the mobile doesnt work so how to switch on my mobile
You particular phone is quite sensitive model
there are three possible reasons,
1::: the flex cable (it is a ribbon that connects the upper face to the lower one) might be damged or a line is cut
2::: the Keypad IC driver is damaged(it is the ic which controls the keypad functions)
3::: the keypad membrane might have accumulated dust and other debris(clening is required)
all of the three cant be performed by the user alone, thus, i suggest you bring it to a technician, slide phone are quite sensitive, being it having a flex cable, so no user can perform this without the proper training and tools to do so.
Aug 17, 2010 | Nokia 6500 Slide Cellular Phone
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
LG Envy 9900 Keypad and side buttons wont work.
try taking out the battery it works on washer  and getting wet incedents it also works on bugs give it a try
Feb 14, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
46 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
