Question about Apple iMac G4 Desktop
IMac disk drive is sick
IMac OS 10.5.7 has sick disk drive. Makes rattling and bumping noises and many times spits out disk. Sounds like it can't get up enough steam to run the disk. What's going on? Love my Mac...
    Novelist:
  • 142 Answers
From what you say this is most likely caused by one of 2 possible issues. Either the lens is dirty, or the laser in the drive is going out.For a dirty lens, just try one of those lens cleaning discs. If this doesn't fix it, then you likely need a new drive. If your machine is still under warranty, just bring it to a authorized mac service place and they will fix it for free. Or you can just get an external dvd burner and plug it into one of your usb ports.
If not, its a fairly simple fix. Since you have leopard then you have an intel imac. You can find the drive you need on ebay for between 40-80. Just run a search for "imac superdrive". This will return the the results you need for a dvd burner that works in your mac.
To replace the drive, you will need a torx set. You can get them cheap at sears or most hardware places. These are the screwdrivers with a star looking thing on the end.
To get into your mac, place it screen down on a towel, so you don't scratch the screen. Remove the RAM cover, the one were your memory is. Then remove all of the screws at the bottom of the mac. After that, lift on its leg, the back panel should lift out from the bottom to the top. In the upper left corner you will see your drive. It will look like the ones in the picture on your search on ebay. There's a couple different ways they put them in there but its always fairly obvious how they come out. Take the old one out and put the new one in, replace the cover, replace the screws and you are good to go.
NOTE: If when you go to lift the back cover, all the guts want to come out, then its a bit more involved to get into it. If this is the case let me know and I will email you step by step instructions with pics. And DON"T try to lift out all the guts from the back.
Posted on Sep 12, 2009
Testimonial: "I found this the easiest and most concise solution! Written for the dummy, not the techie. Thanks!"
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
03 pt cruiser makes rattling noise when put in drive
does it make the noise and goes away within 5 to 10 seconds then it drives and shift fine let me know ok
Nov 27, 2012 | 2003 Chrysler PT Cruiser
When I turn on the computer it takes a while to boot up, and when it does it stays idle for 10 seconds or so then shuts off?
Sounds like there may be a problem with your OS X.
You will need to boot from your OS X DVD and run your Disk Utility to do a repair on your operating system.
To do this, start your iMac and pop in your DVD. Once you hear the boot up sound, hold the Option/Alt key. You will be given the option to choose between your hard drive boot up and DVD boot up, so choose the DVD. It'll take a while longer to load than usual as you're booting from a DVD, but once your Mac has booted up, use Spotlight (Apple + Space, type "Disk Utility") to load up your Disk Utility program. Once you've got that open, select your hard drive on the left and click "Repair Disk Permissions" and then click "Repair Disk."
Once you're done, reboot and your Mac should be working good as new.
Mar 25, 2011 | Apple iMac Desktop
Whenever I drive over bumps it makes noises sounds
It could be your stabilizer bar end link. There common to make noise when the bushings wear out, inspect the end links and replace if needed. You can pick up a up graded end link with urethane bushings that last a life time of the car. They go for around $34.00 for both sides at Part Source. Good luck and keep me posted.
Jan 18, 2010 | 2004 Ford Escape
Front suspension rattles and makes bumping noises when I drive over bumps (even small bumps) and when I turn the wheel either left or right. Possibly a ball/joint problem?
It could be, but check shock bushings, control arm bushings, sway bar and brackets. There are anumber of things that can cause a rattle. The first thing to be done is jack the truck up mput it on stands and start checking before replaceing parts. Pay close attention to shocks bushings and anything rubber.
Nov 25, 2009 | 2003 Chevrolet Silverado 1500
Mac DVD drive issue
Sounds like a bad laser. Try a cleaning cd, if that does'nt work then you'll have to replace it.
May 06, 2009 | Computers & Internet
CD/DVD Drive Doesn't work
Hi, Sorry to hear you are having problems,
One final test to try before declaring the drive dead:
Insert a bootable installation CD or DVD and restart right away. If the system ejects the disk, simply re-insert it as soon as possible after you hear the start up sound and then, immediately press the ( C ) button on your keyboard forcing the Mac to boot from the cd....
If your Mac boots, then the drive is OK it's your system that has a problem.
If the disk is ejected again, then you can declare the drive dead. It is a relatively inexpensive repair and if your Mac is still under warranty, then apple will take care of this no charge.
Good luck
Mar 21, 2009 | Apple iMac G5 Desktop
I did a software upgrade yesterday to OSX 10.5.6 and when my computer restarted by DVD/CD drive no longer works.  When I put a CD in it sort of makes a noise and after a little bit it spits it back out...
Hi There,
9 times out of 10 any faults encountered to hardware during an upgrade are due to a faulty or misinterpreted install. To rectify this download the combo installer from here. It's pretty huge at 668MB so will take ages to download but it should repair our drive situation.
Hope it works out for you
All the best
Sean
PiDigital
Dec 18, 2008 | Apple 2.16GHz iMac Intel Core 2 Duo...
Imac os 10.4
It sounds like the common firmware issue, can you read it at all?, if so download the latest firmware from apple and follow the instructions to install it, get back to me if you have difficulties
Nov 06, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Apple iMac G4 Desktop Logo
277 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
