My computer is saying my printer is not hooked up and it is what can i do
  • 1 more comment
  • rj_hughes_06 Sep 12, 2009
    it is a HP Desktop D2445
    the message says to connect a printer to my computer and I have checked and rechecked all my connections
  • efs_perpends
    efs_perpends May 11, 2010
    You may have to reinstall it, or reinstall the usb controllers, or reset the printer. What make and model printer are you using, on what OS?
  • efs_perpends
    It sounds like a usb connection issue, but to say for sure we'd need to know the make and model # and the exact error message you're getting.
    President:
  • 1,996 Answers
If this is a new installation of the printer, please download the updated HP software/drivers from here and install using it instead of the cd.
If the printer is correctly installed on the system, can be found in the control panel and device manager, and the updated HP software is already installed, it is most likely a usb controller issue, or a conflict with your printer drivers. In any event, please use this HP support article to troubleshoot the problem. If the printer was previously working, you may simply need to reboot the computer to reload the usb controllers and detect the printer anew. If that doesn't work, follow the instructions given there. Also see this page.
If you encounter other errors or have future questions about your model, see its HP home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 12, 2009
  • 125 Answers
Hello, this is a very common problem and the solution could range from very easy to something more difficult. To answer your question, it would take some troubleshooting. Is your printer connected by a USB cable? Most newer printers are, so I will assume this. I would try plugging your computer into another computer and verify that the other computer detects it. If it does, you will see the "detected new hardware" window pop up. Backtracking a bit, most USB type HP printers ask that you first install the software from the HP printer CD first, before connecting your printer. If you don't do this installation properly other issues come up that prevent your printer from installing properly and that's another question.
So to answer your question, first you need to verify that your printer is ok by trying to install it on another computer, or at least be sure that it detects. If it does, then you know your printer is ok. Secondly, make sure the USB port is working correctly by plugging something else into it like a USB thumb drive or a USB mouse, etc. If all of these things are working, make sure the printer is on and connected properly and check the device manager under the control panel and see if there is any printer showing up there. If so, disable or uninstall the printer and try to connect again after following the HP manufacturer's instructions, such as using the install CD first. If you don't have the CD, you can find the software on the HP support website. Google, "HP driver downloads". Your problem is not something that has a simple answer because there are so many reasons why a printer won't detect, but the solution requires a methodical step-by-step troubleshooting like I mentioned above. One of the major problems is that the printer sometimes is not compatible with your computer. You need to verify that the printer is compatible with your operating system and computer. Have you done that? For example some of my HP printers will not work on my new Vista computer because my computer is too new for my older printers. All of these things have to be investigated online by going to the support page at HP.com and verifying compatibility. I hope this gets you on a good start.
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
Bought a used HP1022n printer. Need to hook up to my computer as a local printer. When trying to instal the driver, the set-up says waiting to connect to the computer. I have the USB cable connected,...
Make sure you don't have the printer connected until after you install the driver. If you had the printer hooked up to the computer before you installed the driver, uninstall and start over. There should be a prompt during the installation process that tells you when to hook up the printer. If that doesn't work, you may have a driver for a different operating system than what you have on your computer. If you need further assistance, please email me the operating system you are using on your computer.
Feb 07, 2011 | HP LaserJet 1022n Printer
Hooked up after moving to same compute and Netgear
in printers and faxes menu on your pc, right click on the printer and select "use printer online"
Jul 24, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Dell a920 printer not recognized by computer
Did you install the drivers. If so goto divice manager and enable the divice.
Sep 17, 2009 | Dell A920 InkJet Printer
Is hooked up to computer but says it not hooked op to computer will no print off computer
this could be a communication problem.
you need to make sure that the cable that you are hooking up is the one that came with the printer,also you may need to plug the cable into a different port and check if the computer detects it.
{take intensive care in case you follow these steps. }
there is an entry for USB printing support
and USB composite device in the device manager under USB devices, if you remove these entries. the computer will start detecting the plug and play device and hence will detect the printer.
Jun 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Scaner will not work? Says its not hooked to computer?
Hi! Check the cable of the scanner if it is properly hooked to your computer. Also check all the connection from scanner to the computer. Then turned on your scanner. GOOD LUCK
May 06, 2009 | HP OfficeJet r80 InkJet Printer
Printer won't print says USB is not hooked up
Correct communication problems between the printer and the computer.
  • Remove the USB cable from your printer and your computer. Reconnect the USB cable to your printer and your computer.
  • Turn off the printer. Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable to the electrical outlet, and turn on the printer.
  • Restart your computer.
Aug 19, 2008 | Dell 946 All-In-One InkJet Printer
Hook up
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 13, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
130 people viewed this question
k24674
jasbo
jasbo
