Question about Microwave Ovens
Need to remove broke oven door on spacemaker oven. will it it hard to remove oven.
    Top Expert:
  • Microwave Ovens Master
  • 14,548 Answers
Open door inside panel around glass is held in by snaps gently pry back panel once removed remove hinge screws door off
Posted on Sep 12, 2009
GE Spacemaker Microwave Oven - need to replace auto vent door
IF YOU KNOW NOTHING OF ELECTRICS ESPECIALY M/WAVES LEAVE WELL ALONE THET CAN BE ===LEATHAL===I MEAN LEATHAL.
Oct 04, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I repair the broken handle on my Spacemaker microwave from GE?
you have to remove the trim inside the door. you have to carefully pry the inner trim and kind of twist it as you remove it so you don't break it.
if there is enough of the handle left where the screw goes in(I'm assuming that's where it broke) sometimes you can drill into it a little and put a longer screw on. otherwise you need to buy a new handle.
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle broke off. where can i find another door handle for spacemaker XL1400 ?
If its made of plastic, it is better to buy a tube of plastic weld. They are extremly strong, and I have used them time and again. They are available at auto parts store, and hardware stores. They come in two tubes, and you mix them together.
Nov 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The handle broke on my microwave. How do I remove
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Aug 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door is hard to open
you can solve this yourself by removing door pins and straighting the hinges
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do you replace a broken handle for a GE Spacemaker II microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, the handle may rotate into and unlocked position then lift out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Oct 08, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
